On a similar tip, www.curtlo.com makes custom fillet brazed (cross) frames/forks for even less than vicious cycles. Though less money the frame alone will still set you back almost $700. My guess is this doesn't meet your budget requirements but you never know.SortedCycles said:The Soma Double Cross is canti only. You could, of course, run an adaptor like the one from Paul's Components. If you can stretch your budget then the best choice would be to go with Vicious Cycles. Here's the sort of thing they can do...
Gripfer said:Looking for a frame, budget low to moderate. Have a fair amount of componets, but want to go disc.
What tooth size is the chain ring? Looks real nice... Spot.SortedCycles said:The Soma Double Cross is canti only. You could, of course, run an adaptor like the one from Paul's Components. If you can stretch your budget then the best choice would be to go with Vicious Cycles. Here's the sort of thing they can do...
Can't give you any info on the ring size as Carl sent us the picture so that we could pass it on to one of our customers who is interested in a disc'd Slider. I can't remember the exact size but I'm sure it's either a 46 or 48cm.donkekus said:What tooth size is the chain ring? Looks real nice... Spot.
What size is that bike?
