lmao. No that is NOT why they chose composites. Give it up! Strength to Weight is a real thing.
The Boeing Dreamliner airframe is nearly half carbon fiber reinforced plastic and other composites. Reducing weight by 20 percent compared to more conventional designs.
Cost of the plane is a small factor. Cost of fuel is significantly larger factor. Airlines would gladly pay more for a plane made from titanium if it was lighter and saved fuel costs over 20 years.
BOEING UPS THE ANTE WITH COMPOSITE-LOADED 787-10 DREAMLINER
So, what is it about the 787-10 that makes the plane so attractive? Drastic improvements in fuel mileage and emissions made possible by a full range of composites that make up entire sections of the plane, including the wings and fuselage.
IT'S ALL ABOUT THE WEIGHT
When the Boeing 747 was first introduced in 1970, it was believed that the company had reached the absolute limit in size and weight.
Engineers have to look at a number of factors when designing a new airplane. First is the total weight of the aircraft, including the aircraft itself along with passengers and cargo. Aerodynamic principles dictate that in order to lift a certain amount of weight off the ground, a plane's wing span has to be commensurate. The more weight you add, the bigger the wings have to be.
COMPOSITE MATERIALS ARE THE ANSWER
So, how did we get from the '70s-era 747 to the modern 787-10? By taking advantage of composite materials. Things like fiber composite panels offer superior strength and rigidity without excess weight. In fact, everything from carbon fiber tubing to fabricated sheets and panels offer the strength and rigidity needed for airframe construction but at a much lower cost in terms of weight.
The 787-10 can seat 330 passengers and fly more than 6,000 nautical miles because of the advantages of composite materials. It is a 224-foot aircraft with a wingspan of just under 200 feet, so every major airport in the world can accommodate it. Its main advantage is fuel savings.
By drastically reducing fuel consumption without sacrificing seating capacity, Boeing has created an aircraft that generates higher revenues per seat. In the ultra-competitive world of commercial airlines, this is everything.
