1 - 7 of 7 Posts
Hi all.
I got a Specialized Allez recently and it came with descent Roval CL64 wheels. It's a wide rim and ETRO is 622x21. On specialized website it says 20.7 internal width and external is 29.9mm. It came with S-works 24mm tires stock. Overall, this combo have a nice profile, however, I'm thinking about bigger tire. How wide? Does anyone know, if 28mm is a good option? I don't want em wider then a rim (i.e. keep aero profile). How can I get a tire that's tall, but not too wide?
Vic
Banned Sock Puppet
Hi all.
As long as they will fit in your bike frame, this is a great option. Wider tires don't need as much pressure, so they will have a more comfortable ride.
Vic
Unlike car tires, there is no way to get a bike tire that is selectively taller. Wider tires are automatically taller. And unless you race or consistently ride over 30mph, you won't even notice the aero disadvantage.
But tire will be a bit wider then rim? Do you think this still makes sense on high-profile wheels?
Banned Sock Puppet
As I said, you won't notice any aero difference. The only thing you will notice is a less harsh ride. Keep in mind that the rider creates way, way more wind resistance than any tire can.
changingleaf
A 28mm tire is a great option if it will fit in your frame. Tire size labels do not always match the measured size. The most recent 28 I used was a Hutchinson Sector 28mm. It measured almost 29mm wide on a rim of similar internal width.
Banned Sock Puppet
This is true. And from what I have seen in many posts here, Continental tires seem to run larger than stated.
Also keep in mind that the same tires will measure wider on wider rims. The tires I use measure the advertised width of 28mm mounted on 15mm rims. They measure 29mm on my 17mm rims.
I have aluminum HED Ardennes+ rims. Those are 25.5mm outside, 20.7mm internal. They are tubeless compatible, so the beads snap into place, and need thumb pressure to pop loose when deflated. I think this is a good idea for running really narrow tires on wide rims, to help keep the bead from coming loose, since it's essentially pulling almost straight up.
23mm GP4000 measure 26mm. So I inflate the same as I would a 25-26mm tire: 80 to 85 psi front, 90-95 psi rear.
25mm GP4-season measure 29mm. I use 60 to 65 psi front, 75 to 80 psi rear.
I'm guessing that your 28mm tires would be somewhere around 32-34mm wide on your rims.
1 - 7 of 7 Posts
