I’m talking about suspension or impedance losses. If u bother to read what the links say and what I’m saying you’d find you’re actually agreeing with me in that the body converting possibly hundreds of watts in momentum to heat seems unrealistic. That’s what they say. That’s the definition of suspension or impedance losses
www.renehersecycles.com
but there’s room for variables as written below (gotten from discussion at bottom of the link just above): Micro jumps.
“However, I am not sure that this suspension losses are caused by vibrations in the body tissues. They could be trivially caused by micro-jumps due to road irregularities. In a jump, part of the energy is probably lost in the landing and not converted in forward motion. Even Josh Poertner seems to suggest a similar explanation.
However, apart from my hypothetical explanations, to establish if the losses are due to body tissue vibrations or micro-jumps, would be hard to do. Probably one should use a trike (able to travel for short distances with no one on board) with ballast and on a slope, and see if the results are the same, that is lower pressure leading to faster speeds. If the results are confirmed also for an unammend trike, then the reason for suspension losses is not body tissue vibrations but micro jumps.”
(the solid ballast (concrete) vs water/fat/bone roll test I also proposed).
the energy of course has to go somewhere. Bike suspension forks heat up but is it the spring itself’s internal friction, which would be analogous to our body on the bike, or is it friction of the other fork parts.
