1 - 13 of 13 Posts
No.
Why $160? Your campy brakes don't have holders?
Buy some Jagwire ones. Ebay has them cheap.
Just get some Koolstops. If you're going to replace pads why not get some that are better?
And I don't know if that Branford price is a misprint, or Campy has gone completely bonkers.
Edit: I see you found 'em. That's the ones.
I think a full set of Campy pads is about $40. Where are you coming up with $160?
Campy pads fit in the Campy holders. If you want to use different pads, you'll need different shoes (as they're called).
waterproof*
Discussion Starter · #9 ·
it's because I have crabon wheels for racing and alu for training, and I like the Kool-stop salmon for the alu but want carbon specific for racing. and it's a PITA to switch out pads.
Yes it will work. I had a campy 9spd setup that I wore the pads out on. I just used the pads and holders off a set of Shimano brakes I had laying around. It was a few years ago but if I remember correctly the Shimano pads and carriers are a different stack height (from brake arm to rim) then the campy pads and carriers. Should be able to adjust back and forth using the tension adjuster though.
Adorable Furry Hombre
This is what I do, since my fav LBS around here never stocks campy pads. The Koolstops work great.
Swissstop makes a pad that can be used for both aluminum and carbon. They come in Campy and Shimano and slide in the brake shoe.
waterproof*
Discussion Starter · #13 ·
Yeah I know and so does Zipp and probably others. But I like the kool stops on aluminum and I'd rather have the best pad for each rather than a compromise for both.
1 - 13 of 13 Posts
