good choice
I have the same bar but labeled under another manufacturer. This bar fits me well since i have carpal tunnel on the R hand and the condition worsens when i use regular sized bars. This bar is very comfortable once you get it into your sweet spot, i needed a lot of fiddling to get it into my most comfortable position. My hand doesn't act up as much . The drops are wider than the hoods. My drops are 42 cm c-c, but the hoods are 40cm c-c. The bends are lower than the center of the stem. the rear center of the bar has indentations and are good for resting your thumb but you really need to position this bar to make it work effectively. The cable grooves under the bar have been sufficient. My cables have not come out of the groove even when i hit potholes or bumps. it doesn't feel as stiff as an aluminum bar and it needs some getting used too.
i have an aluminum truvativ ergo-anatomic handlebar and it does not compare to this. I would definitely get this bar for my other bike. i can't upload pictures to RBR but i can e-mail someif you're interested in my set-up. Hope this helps
TheCapman
