1 - 15 of 15 Posts
Beetpull DeLite
And where did it come from? Appears to be a replacement for the D60 or somethin'? Judging by appearances, the AF motor was again left out.
Review RoadBike Member
The AF motor WAS left out... it supposedly has the D90 sensor... and a moveable LCD. kind of a step between the D60 and D90
Spicy Dumpling
With 720p video.
still shedding season
Seems like they're really pushing the video capture with that one. Meh. But I do like that swivel screen, like the one on my Coolpix 5000 that they made in about 2002 and then seemed to forget all about.
Roadies Rejoice
All you wanted to know about teh D5000 ( and the Canon SX1)
April 16, 2009
State of the Art
The Quest to Shrink the S.L.R.
By DAVID POGUE
Physics can be such a bummer, you know? Those doggone rules of nature make our luggage heavy, melt polar ice caps and conspire to make the toast land jelly side down.
And physics explains why you can’t take professional-quality pictures with a small camera. Big, bright, beautiful photos require big sensors and big lenses to shine on the chips. So we’re stuck with two camera categories: pocket ones that take mediocre pictures and big heavy black ones (S.L.R.’s) that take stunning photos but require a neckstrap or, ideally, a wheelbarrow.
Because both ends of that spectrum are already teeming with camera models, the manufacturers are eager to differentiate in hopes of finding new markets. This month, Nikon and Canon are going for a category that, so far, is sparsely populated — the one right in the middle.
Call it the mini-S.L.R.
Nikon’s new D5000 ($850 with lens) and Canon’s PowerShot SX1 IS ($600) look very similar. The bodies are sized and shaped identically — like mini-S.L.R.’s —and they weigh roughly the same (around 1.5 pounds).
Each camera can capture high-definition video; each even has a mini-HDMI jack for connecting to your hi-def TV. (Mini-HDMI requires a special cable, not included.)
Each has a flip-out, swiveling screen on the back. That feature permits you to shoot at high, low and side angles, not to mention allowing self-portraits. (Nikon’s screen flips downward below the camera, rather than off to the side — an arguably better design, since it keeps your view in line with the lens.) But a flip-out screen also gets the big black camera away from your face, thereby getting more natural, relaxed expressions from your subjects, especially young ones.
Despite these similarities, though, these cameras approach the middle from opposite ends. Nikon has tried to consumerize an existing S.L.R.; Canon has tried to S.L.R.-ize an existing consumer camera.
The Nikon D5000 is a genuine S.L.R. It takes interchangeable lenses, its eyepiece lets you peer out through the lens itself, it has an enormous light sensor inside, and it has no shutter lag (the delay after you press the button).
In fact, if you just read the brochure, you might mistake the D5000 for Nikon’s more advanced, more expensive D90 ($1,150 with lens); the sensor inside, the specs and most of the features are exactly the same.
The D5000 has the same superb 12.3-megapixel sensor, the same sensor-shaking mechanism to eliminate dust spots, and the same 11-point autofocus system, which makes it easier to compose focused shots. It even has the same burst rate (4.5 shots a second), which is fantastic not just for sports and action but for capturing fleeting facial expressions.
Like most S.L.R.’s these days, the D5000 also has Live View mode. It makes focusing slower, but it means that you can frame your shots using the screen, if you like, instead of holding the camera to your eye. The D90 was the first video S.L.R.; the D5000 inherits that hi-def goodie, too.
But here’s where things get crazy: Nikon has packaged all of these professional features into a much smaller, lighter camera that’s obviously aimed at amateurs. For example, the new camera is loaded with scene modes to make the thing less intimidating to novices — canned presets for Sunset, Pets or Beach/Snow, each with a sample photo on the screen.
As on other recent low-end Nikon models, the D5000 also makes photography easier to understand by displaying a visual representation of the actual aperture (lens opening) inside as it grows and shrinks. The screen also indicates your shutter speed both graphically and with a fraction — “1/25,” for example, rather than the “25” that appears on most S.L.R. screens. (The D5000 lacks a top-panel status screen like the big boys have — one casualty of the smaller body.)
The D5000, in other words, is such a mix of high- and low-end that Nikon’s representatives actually asked my opinion on how to describe the thing. Here’s my suggestion: it’s a professional camera trapped in a consumer-cam’s body.
A few perks of the D90 are missing on the D5000. You lose the ability to use some older Nikon lenses. The battery is smaller, good for 510 shots on a charge instead of 850. The camera doesn’t communicate with wireless flash attachments.
There are some consolations, though. A new Quiet Mode slightly muffles the clack of the shutter. Focusing before you shoot a movie is faster, although, tragically, you still can’t change focus while filming a movie.
The upshot here is that the D5000 produces spectacular, sharp, fast, brilliant photos in all kinds of light. It has the same expensive guts of Nikon’s higher-end models in a small, rugged, lovingly designed, user-friendly body — and it’s a home run.
You can’t say the same for Canon’s new PowerShot SX1. It’s an evolution of the PowerShot S IS series that arrived in 2004; the IS stands for image stabilized, and the S indicates a camera that’s equally good at movies and stills.
Unlike most cameras, for example, the SX1 can change focus and even zoom while you’re filming — the lens motors are so quiet, the excellent stereo microphones don’t pick up its sound. It even has separate shutter buttons for video and photos, so you can snap a still in the middle of recording video.
What made the SX1 such a hotly anticipated model, though, is its light sensor. It’s a CMOS chip, the type that’s found in S.L.R.’s, including Canon’s popular Rebel series. It’s much more powerful than the chip found in regular consumer cameras. That doesn’t do anything for photo quality, but it gives the SX1 several features that its predecessors lacked, like a very high burst mode (4 frames a second) and full high-definition movies.
All that and a wide-angle, 20X optical zoom lens (that’s not a typo). Where do we sign?
Unfortunately, the SX1 simply doesn’t take great pictures. It’s a feature list in search of a camera. In bright sunlight, you’ll adore the thing. It’s fast, it’s easy, it’s always ready, and the photos are sharp and saturated. But as the light dims, so does the quality.
Noise (graininess) begins to appear even in outdoor overcast shots (say, ISO 400) — and when the camera’s software tries to iron out that graininess, you get soft edges and lost detail.
Unless you dial down the exposure, the SX1 also tends to blow out the highlights — that is, it turns brighter areas of your photos into bleached blobs of nuclear white.
The SX1 also has, in place of a glass eyepiece, an electronic viewfinder (a tiny screen inside the eyepiece). That’s O.K. if that little screen has excellent resolution, but this one is so coarse, you actually see the pixels. Not good.
Camera-testing Web sites like dpreview.com and testfreaks.com have compared the SX1 with its less-costly sibling, the SX10 ($340). The SX10 lacks the CMOS chip and hi-def video — but takes better photos. Weird, huh?
It’s so unlike Canon, which makes the world’s best small cameras, to introduce a model with these compromises. It’s so cool to have a 20X zoom available, a dedicated button for switching between widescreen and standard modes, all those manual controls and the option to use standard AA batteries in a pinch. But for $600, you deserve a camera with a sensor that is up to the light-gathering task.
What the world really wants, of course, is a whopping big sensor like the D5000’s — in a shirt-pocket camera. Unfortunately, you probably won’t find a chip like that in a camera much smaller than the D5000 itself — at least not until there’s an amendment to the laws of physics.
E-mail: [email protected]
Windrider (Stubborn)
It's a replacement for the D60.
Aimed at consumers
no internal focus motor...aimed at consumers
30 scene modes....aimed at consumers.
Len
Seat's not level
Aimed at consumers
Len
Developing products for consumers...:rolleyes: :rolleyes: :rolleyes:
Soooo overrated...
Captain Obvious
weltyed said:
so when will we see prices of the d60 and canon xs come down?
for realz
Premium Member
Soooo overrated...
Why do you hate consumers?
BTW these cameras sound a lot like my Olympus 420 that is a joy to carry and use.
Seat's not level
I like consumers. I was going for some sarcasm and missled. :mad2:
Actully I think it's great that the camera co's are coming up with better cameras for non-pros. Heck, I fit that category. I'm having a lot of fun with my D50. Even got my dad into buying a D40 and he's running around taking more pictures now than he has in the last 50 years. He's having fun with it.
Kind of like bike co's selling comfort bikes. Bike snobs despise them, but hey, if people want to ride them I'm all :thumbsup: :thumbsup: :thumbsup:
Soooo overrated...
I think it's a great thing. If I gave any other impression, it was unintended..
I was responding to girch's OP
Seat's not level
I want a d90, or d300, but I don't have to worry about getting one anytime soon. :(
1 - 15 of 15 Posts
