1 - 8 of 8 Posts
I purchased a Giant TCR with stock Xero Lite XSR3 wheel set a couple of years ago. I have no clue whether or not an upgrade is in order, though I hear that is one of the best bangs for the buck (next to training more/better). I do not hear a lot about these wheels-good or bad. I have not started racing yet, weigh 165 lbs, but mostly club ride with a lot of local "racers' and hang alright with the fast group occasionally getting dropped (not often). I am not ready to throw down $2,000 on a set of wheels, but would like to get faster if I can do it without dropping too much. Are the Xero's good, should I consider the Neuvations or others?
I've been riding/racing (Cat 5->4) on the XRS3's on my Giant for the last two years. The only issue I can think of is when you get around to truing them, the nipples (alloy?) got torn up as I tried to true the wheel. I had to replace about 5-6 of them in the process. The tension is higher than a 32-spoke wheel, my spoke tool trashed the nipples. Aside from that, they've held up rather well.
durable but heavy..
i used to have a set -- never had any problems but found them to be a bit heavy.
the weight for the Xero XSR-3 wheelset is 2048g, compared to the Neuvation R28 SL3's that I'm currently riding, which is 1540g. that's about 1.12 pounds in weight savings...
i bought the SL3's from my LBS for $280 versus the XSR-3's, which were purchased off eBay for $125. while not particularly expensive, the SL3s were still a bit more than the Xero wheels. i've been very impressed with the neuvations so far, and really notice the weight difference when climbing.
Make sure your using the right tool
Using to correct size and a high quality spoke wrench (Park) will prevent rounding out your nipples. Using a "multi" spoke wrench is almost guaranteed to round out nipples, even if its the right size.
In eight years I worked as a bike mechanic, I trued 1000's of wheels and built a few hundred. I rounded a few nipples (both alloy and brass) and pretty much every time it was my fault for using the wrong size wrench.
:thumbsup:
1 - 8 of 8 Posts
