1 - 3 of 3 Posts
Has anyone seen or knows about the Xlab disc wheel if it is good quality? Is the surface of the xlab disc wheel smooth and completely solid? or does it have small air gaps as described below
I saw a hed disc and the surface was not completely solid, as there was small gaps where the epoxy did not fill in the carbon fiber surface. Such as between the carbonfiber weave were not enough epoxy was applied so you can see the inner foam (honeycomb) material.
Does anyone else know of clincher disc wheels? After looking at a lot of things I have decided to go with clincher wheels and not tubular so I am only looking for clincher wheels.
Be as detailed as you can. Any other info will be great.
1 - 3 of 3 Posts
