1 - 20 of 44 Posts
Cat 6
Got a new garage and I'll need to get it set up for bike storage next month. Can ya'll post some pics of what works for you, why, and how you did it? I'll be hanging/storing 5 road bikes, 1 MTB, a Kid's bike and eventually 2 beach cruisers. Just curious on what ideas other people have used.
Lost in Space...
I use a bookshelf to hide the entrence to my secret cave. You simply pull a book out (I won't say which but it's probably the one with the grease stains), and the entire shelf will rotate you into a secret chamber. Then you slide down the pole and get off on the third floor (be careful not to get off on the ghostbusters floor, the batman floor, or the muppet-babies closet floor).
But seriously, great thread idea. I have nothing constructive to add at this time.
More cowbell!
I use hooks like the yellow ones above, screwed in at 90 degrees. If you screw them into the studs behind your drywall the 16" on center works well if you invert every other bike.
I have mine on these hooks I have found at Walmart they are about $5 a piece, work well for me. I always have my bikes up on the hooks unless they are being ridden, keeps them out of eyesight of passerby types and harder to steal if they do look in my garage, also out of the way of getting bumped or scratched while in the garage.
Here is a link, don't know what is up with the price in the link but at our local Walmart is was $5 and change each.
Racor ProStor Bike Hanger: Bikes & Riding Toys : Walmart.com
Tell us about that car in the background.
- I -
I have 12' ceilings. I was tired of the Racor lift things with the cords hanging down.
I built a storage rack based on this video:
Garage Trailer Lift Storage - YouTube
I bought a hoist from Northern Tool. I bought an upright from a pallet rack (think the shelves in Home Depot), and I bought some pulleys from Grainger and had some cables made by one of the rigging companies I found on the internet.
It works the same as the one in the video. I push the button, and the family's bikes go up and down. I raise it to the top and I can park my car under it. No ropes to mess with. It's quite handy.
But building something like this is not for everyone. If you are a handy engineering type it wouldn't be bad.
Cat 6
Discussion Starter · #10 ·
Finally got it set up. I screwed in 1 x 6" into the studs. The drilled the rail system (Lowes) into the 1 x 6". Works great and room for expansion!
V Nice. V Nice! I like that rail system, saw it the other day. Have been doing the hooks into a 2x10 for years, but thinking of switching for flexibility too esp as the kids grow.
BTW ... I have to complement you on your taste in bikes .
I had an AAR 'cuda, same year. Still kicking myself for selling it even though it wasn't original -- the guy I bought it from had pulled the 340 and dropped a 440 in its place. I made enough money pumping gas, cutting grass, and helping a waterbed distributor to be able to afford it when I was in my senior year of high school (1972/73). Very good memories.
I store my bikes in the basement but it's essentially the same thing. I store 9 bikes on a 10 bike PVC bike rack I built, it cost less than $100 and it was easy to put together. Also buy a pvc pipe cutter, it cuts straighter than using a saw and there's no burrs to file off.
this is the plan I used called the DIY Bike Stand, it's the easiest to build and the easiest to add another space later in my opinion of course, I tried a different one shaped like a triangle and it was a pain, this one was a breeze.
bike junkie: DIY Bike Stand
I first made a test rack using 3/4 pipe and found it a bit too flimsy for my taste and knowing I was going to make it hold more than one bike I knew I was going to have to make it stronger, so I made some changes for the above rack to give it more strength. I used 1" pipe instead of 3/4. The interesting thing about using the 1" is of course you have to use 1" elbows and T's which makes the stand up (the part the wheel will go into and actually hold the bike) a bit wider which makes a road bike fit a bit sloppy, which I figured it would, so I added foam bike insulation to the uprights which makes the wheel fit snug and the pipe won't scratch the rims or spokes now, mountain bike wheels go right in without the foam. If you go larger diameter pipe like I did you will have to cut the small insert section that goes between the T's to 1 1/2 inch instead of 1 1/4. Also since my rack is all one rack not 10 separate racks, I used T's instead of elbows that contact the floor to hold the rack up off the floor a tad, I only used the 2 elbows on the each end of the rack (4 total).
If you decide to build a PVC pipe of any design given on this thread make sure you assemble it first without glue so you can correct any mistakes you may have made, than resemble and check again, once your satisfied with the rack then take it apart and glue it back together. If you plan on adding rack spaces later you can leave the ends unglued then all you have to do is pull the end elbows off, add in a new space. I used Monkey Glue to assemble the pipe because I had some of that laying around, but Monkey Glue gives you time to move pieces of pipe to make sure it's in the right position for proper alignment, pipe glue sets fast and may not give you enough time.
... I store 9 bikes on a 10 bike PVC bike rack I built, it cost less than $100 and it was easy to put together......
THX for the link, plans, and directions. I am thinking of making one of those in a three bicycle configuration that would fit in the bed of my pick-up truck. I don't drive to the bicycle paths very often. But it would make taking the wife with me for a Sunday ride much easier.
1 - 20 of 44 Posts
