This is the next step in the build process for my custom frame from Mike Zanconato up in Worcester, Mass. First we chose lugs: http://forums.roadbikereview.com/showthread.php?t=46871
Tubes and lugs came in. The tubes are Dedacciai Zero (aka SAT 14.5). The steel importer is Joe Bringheli is Ohio: http://forums.roadbikereview.com/showthread.php?t=49006
Then he built a fork: http://forums.roadbikereview.com/showthread.php?t=49478
Then he mitered the tubes: http://forums.roadbikereview.com/showthread.php?t=60591
Now he is going to braze the tubes. In my first photo, the front cluster is pinned and fluxed and ready to be brazed. It's done in a jig whether the builder is using pins or tack brazing. Because the angles fit together so well, Zank said, he was able to pin it and it stayed aligned. If he has to bend the lugs on some unusual design, sometimes he must to tack it. Pins are finishing nails driven into small-diameter holes in the lugs and tubes.
