FWIW: Wider rims increase the installed width of a tire. 23mm tires on 23mm wide rims are ~25mm wide, making it similar to using a 25mm tire on a 19mm rim. They can be run similar pressures, have similarly wide contact patches and increased volume, but the more vertical sidewall on the 23/23 combo is said to improve handling in corners.
