I am buying some Zipp 404's, probably from wheelbuilder so I can avoid the Zipp hubs and I wondered if it was worth going for a 24 spoke rear wheel? I weigh 175lbs.
I don't really know that 4 more spokes would make the wheel any stronger. 404 rims are damn strong and 20 spokes seems to be what Zipp thinks is fine. On the other hand 4 more spokes won't add much weight at all, so why not? If you're worried about it or have a history of being hard on wheels then go for 24.I am buying some Zipp 404's, probably from wheelbuilder so I can avoid the Zipp hubs and I wondered if it was worth going for a 24 spoke rear wheel? I weigh 175lbs.
The reason (or at least one reason) for more spokes is that the wheel is more likely to be rideable with a broken spoke. Not sure if that particular rim would be rideable, but it would be better than with 20 spokes.I am buying some Zipp 404's, probably from wheelbuilder so I can avoid the Zipp hubs and I wondered if it was worth going for a 24 spoke rear wheel? I weigh 175lbs.
