I keep popping back tubes. Both were installed by a bike tech. Is there something in the rim
What do you mean by "popping"? Are they actually going BANG! or you're just getting flats. You need to provide significantly more detail before you can get any meaningful advice.I keep popping back tubes. Both were installed by a bike tech. Is there something in the rim
You keep saying "popping a tube" without explaining what exactly you mean by the word "popping." There's a significant difference between a tube "popping" with a loud sound and a tube just going flat. A loud pop indicates that the tube was able to escape the confines of the tire or the rim—almost always because of installation errror or, less common, because of a substandard rim strip on a rim with spoke nipple access holes. Just going flat without a loud sound indicates something is punching a hole or holes into the tube—usually a small foreign object or objects stuck in the tire.It popped at tube without me even riding on it. I'm gettin to the point of buying a new back wheel
You're not getting it swm. You're providing no relevant information. Where is the hole in relation to the tire and the rim? On the outer circumference?(indicating to a tread perforation puncture). On the inner circumference? (indicating a rim tape issue).Bought that tire brand new the day before the first flat. I ran my hands through it nothing is in there. I ran a layer of electrical tape over the rim tape in hopes it helps now I need a tube it went through all of mine
If you need to check pressure during a ride then you have a slow leak somewhere. I find that I lose 10-15 psi (1 bar) per WEEK. That is with Michelin ultralight butyl tubes (70 gm).My take is its tire pressure. If you are not checking your tire pressure before EACH AND EVERY ride then you are going to get flats. I often check pressure during rides when I stop.
I don't and I don't.
Then you're paranoid or something.I often check pressure during rides when I stop.
