11 Speed Chains: Chorus vs Record?
4.3K views 3 replies 4 participants last post by  Bocephus Jones II
#1 ·
Any preferences guys and gals? Price difference is negligible, maybe $5 on ebay, and about $12 retail. For those that run Chorus cassettes with Record or Super Record gruppos, do you also pick Chorus chains? I recently bought a 2010 R11 gruppo and ordered a Chorus cassette separately but still need the chain. Question I have is does Record and Chorus cassettes/chains wear differently and so is it better to stick with the same models? Thanks all.
#3 ·
the difference...
The only difference is Record has hollow pins. There should be no difference in longevity, just a small weight savings with Record. It should be easier to peen the end of a hollow pins, so there's nohting to suggest the a Chorus chain would be stronger. When chains "break" it's nearly always a plate that gets pulled off the end of a pin.
I would buy Chorus, just because it's cheaper.
#4 ·
Hell buy a Centaur or KMC chain FWIW...I am running a Record chain now, but only because that's all the LBS had and I needed one quick--that sucker was shiny for a day or two and it was $$.
