Bought an Easton EC90 SL 1" steerer. My front brakes (Campy) has a brake bolt that won't fit all the way in. Any suggestions?
Yout get a nut for the mounting stud with the brakes. Some forks have such a long length of engagement that they come with their own their own special nut.Ken said:Does Shimano differ from Campy in regards to brake bolt dimensions or are they both the same?
I had no idea the nut was 30mm long! A shorter nut is indeed the fix. I've added the suggestion to merely cut the nut shorter. Simple solution, since most of these nuts are full threaded.PeanutButterBreath said:Good point. Based on OPs description and picture, I took the problem to be a too long bolt not a too narrow hole.
