I'm 5'10" with a 33" cycling inseam. I tried using the fit calculator at wrenchscience.com and this is what it recommended:
Height: 70.00 in
Sternum Notch: 57.00 in
Inseam Length: 33.00 in
Arm Length: 25.00 in
Shoulder Width: 16.00 in
WS Recommended Road Sizes
Frame Size center-to-center: 54 cm
Frame Size center-to-top: 56 cm
Overall Reach: 66.23 cm
Saddle Height: 74.01 cm
Handlebar Width: 42 cm
Based on the above, it looks like I should get the CAAD10 in size 56. The size 56 has an effective top tube length of 56cm and with ~10-11cm stem length would put it right around the 66.23cm overall reach recommended by wrenchscience.
I'd like to get some initial feedback here before I go and try this bike out. So, does a size 56 CAAD10 sound okay based on my measurements? Or should I step down to a size 54? And those of you with similar measurements, could you chime in with what size bike frame you have? Thanks in advance.
Height: 70.00 in
