What are your thoughts on hot waxing and does anyone have experience with the brands above? Seems like some brands are more complex than others when it come to the process.
A 6 pack of links at 5x use is 30 uses.So you only re-wax every 2,000 miles?
Ooops! Brain fart on my part. So that would be every 333 miles. That makes more sense.A 6 pack of links at 5x use is 30 uses.
No it doesn't, I used it for about 18 years and learned from the first time I used it, don't back spin the chain fast, if you do it will splatter, if you don't it leaves very little mess. I put paper towels down because like any cleaning method, such as spray on and wipe, they will have some dripping, but not splatter if you don't crank the chain fast.That Park Tool chain cleaner makes a horrible spattery mess.
I use Molten Speed Wax. Works great. I think it's the best priced option.
They are? What are the more complex processes?
I am just curious about it, I have been seeing a lot of it on the gravel scene and seems to work well. I like the idea of clean and long lasting but am here to try and learn moreSo THAT's why my chain is hairy!
Seriously, it's only been 6 hours since the OP posted. Good grief, give the OP the benefit of the doubt before you declare a new member a "one post wonder who's pumping one or more of the products". Waxing isn't for me, but to each their own.
Okay sweet, that’s good to know! I am excited to try it out!Back when I was a teen, and the universe was in its infancy, I melted paraffin wax in an coffee can. It worked fine, but really was a hassle. Now I use Silca. I also use their drip wax between the hot wax to extend its life. I don't know if it's better or worse than the other brands but it works for me. I also really like their customer service. Very quick shipping and very quick with answers to any questions I have.
I think the writeup @tinball made is pretty thorough and informative:I am just curious about it, I have been seeing a lot of it on the gravel scene and seems to work well. I like the idea of clean and long lasting but am here to try and learn more
Thanks, I appreciate the insight.I use wax lube (hot and drip) on some bikes and oil based on others. I think the main question you need to ask is why are you interested? Then, is the "juice worth the squeeze" to go to wax?
I use Silca hot wax and the drip to extend the time between hot waxes. I used to do the crock pot method but then purchased the Silca wax system and that made things a good deal easier overall.
First I'll say this... If you ride a lot in wet conditions, just don't do it unless you really really really like going through through the whole waxing process often.
I'll try to keep this as short as I can.
Pros:
Cons:
- It's cleaner to the touch and in general with some caveats. If I drop a chain, grab it put it back on and jump on bike and roll. No need to clean fingers or hands after touching the chain. That was my main reason for switching.
- It doesn't wear the drive train as quickly. This is the reason I have stuck with hot wax on my main ride. I have 2 chains I rotate and still have less than .5 wear on both (after boiling hot water cleaning before re-imersion treatment) after 2.5 years and guessing milage of at least 12k miles if I exclude a chunck for trainer bike virtual "miles". Thats probably around 6k per chain so far. Those are Shimano HG701 Ultegra/XT and KMC X11SL chains. My rings and cassette are also not showing any excessive wear either and shifting is still great.
- Supposedly is faster and save watts... I don't care about this but if you are looking for every single possible advantage in racing, it's a consideration.
- It's quiet ****. Asterisk for a reason. When fresh and maintained and you are not crossed chained, it can be near silent.
That's my take and experience - sample size of 1.
- It's ALOT of faf to get started. You need completely clean your WHOLE drivetrain. Everything that the chain will touch will need to be stripped of any oil or grease if you don't want to contaminate the wax. Chain, rings, pulleys, and yes the derailleur cages. I know people who skipped this and then had sub par results from the wax not lasting as long as it should or black grease like wax on their chain and it not being "clean" like I said above. If you are going to go to the trouble of using hot wax don't skip the prep.
- It's more faf to maintain. Some people don't mind this. Some find it worth it for waxing. Others not so much. You have to be more diligent on maintenance. This means you should wipe clean your chain after every ride. You can also use drip wax to extend the time between hot wax immersions. You can also rotate chains like I do, but at some point, you have to take the time to clean and dip the chains. Then break in prior to putting on the bike (not required but I find it helps with wax buildup and allows for much faster swaps on the fly if necessary).
- It can be noisy, when you need to re-wax or are severly crossed chained, it can be loud.
- It can be dirty. Wax will get on everything around your drive train. I will not use it on my trainer because I do not want wax bits all over my floors in the workout room - if it gets into carpet it's a real PIA to clean!!!. It will gum up your rings, pulleys, and in your cassette over time if you do not scrape them regularly. This is simple to prevent and takes less than 5 minutes - if you don't let it build up. Whenever I swap chains, I just scrape them with a plastic wedge. Same goes for wiping the derailleur cages with a cloth and rubbing alcohol.
I just got a hot wax at SBT Gravel by one of the vendors and can objectively say it was WAY better over a 100 mile gravel ride. I have used a log of dry chain lubes but nothing has ever been so smooth and so quite in my lifeThis is not a big deal. It's not the whole waxing process where you need to strip a chain and start from scratch.
After a wet ride, throw the chain (even if wet) into the hot wax and renew it. Other than waiting for the wax to heat, it's a <5min process.
Even with oil lubed chains, you should dry off the chain to prevent rust. And clean/relube more often if you ride a lot in wet conditions
The cleanliness was my main reason too. If you travel with a bike, it's so much easier and cleaner than dealing with a greasy chain and drivetrain.
I was dubious of the chain life claims. And it wasn't my reason for switching. I've never had an issue with chain life. But DAMN. Chain life is far and above anything I've ever seen.
I'm rotating two chains, each has 4,000mi. I recently measured zero wear over 12" (on both chains). I couldn't believe zero wear was possible. So I measured the whole chain. And I found ~1/32" over 50". That's only 0.06% wear. The chains should last over 12,000mi.
Agreed. I don't think I'd want to switch over a used oiled drivetrain. And definitely wouldn't attempt to switch a used oiled chian.
I've only waxed on my new purchased bike. I haven't converted over all my other bikes.
I find the exact opposite. It's a breeze to maintain... as in zero maintenance. I never wipe my chain and there's no wax buildup on the rings, cassette, or pulleys. Perfectly clean.
That's the greatness of waxing. Far less maintenance than oiling.
I don't find them to be any more noisy than an oiled chain that needs to be relubed.
Don't you have a sweat towel/mat under your trainer anyway?
You can get oil lube on the floor too.
I don't have this problem.
It's been over a year and no wax to clean off.
Think of it as your initiation.Hey y’all appreciate the insights. It sounds like a large portion of this forum doesn’t like or approve of waxing but I still want to try and discover that for myself!
I might be a “one post wonder” I might not. I guess anyone who post to this group for the first time has to deal with that type of grief.
Here is a forum member you can have a lot of conversation with --> https://www.roadbikereview.com/threads/lets-talk-waxing.386097/Hey y’all appreciate the insights. It sounds like a large portion of this forum doesn’t like or approve of waxing but I still want to try and discover that for myself!
Whew. For a moment I thought you might be directing our new member to take on our recently joined belligerent "Olympic champion". But, I imagine anyone who wants to make their first post asking about chains waxing, has fairly thick skin, or will develop it fast.Here is a forum member you can have a lot of conversation with --> https://www.roadbikereview.com/threads/lets-talk-waxing.386097/
Are you racing? If not, why are you wanting to hot wax your chain? Do you think that by hot waxing your chain you'll go on a 100 mile ride and get back 30 minutes sooner? No you will not, the quickest you would get back home is just a lousy roughly 1 minute from going from say Silca Super Secret drip wax to immersive hot waxing. So if by chance you can average 16 mph on a 100 mile ride, it will take you 6 hours and 15 minutes, by hot waxing it will take you 6 hours and 14 minutes, are you really going to notice that 60 seconds?What are your thoughts on hot waxing and does anyone have experience with the brands above? Seems like some brands are more complex than others when it come to the process.
This sure was a mouthful. I'm sure most people who hot wax are focused on cleanliness, not an extra watt or two. I've tried a few wax "dry" lubes and was unimpressed with them all.....including Rock n Roll. It wasn't even clean, it made the drivetrain gummy. And forget about trying to apply it was it was below 50 degrees.Are you racing? If not, why are you wanting to hot wax your chain? Do you think that by hot waxing your chain you'll go on a 100 mile ride and get back 30 minutes sooner? No you will not, the quickest you would get back home is just a lousy roughly 1 minute from going from say Silca Super Secret drip wax to immersive hot waxing. So if by chance you can average 16 mph on a 100 mile ride, it will take you 6 hours and 15 minutes, by hot waxing it will take you 6 hours and 14 minutes, are you really going to notice that 60 seconds?
You will spend a hell of lot more time then 60 seconds going through all the trouble of hot waxing your chain!
Now there is the point that can be made that a hot waxed chain can last longer, but trying to find an average difference between a hot waxed chain and wax drip chain was impossible on the internet, but I doubt the difference is more than 500 miles. But to get those 500 miles you'll have to remove that chain, clean the chain, hot wax it again, and reinstall it every 150 to 250 miles. I did read the more you hot wax it, like at the 150 mile mark the longer the chain will last, but no numbers were given. Also if you get caught in the rain, as soon as you get home you have clean it and hot wax it again. The expense of all of that clean and waxing, plus time, and in my book time is money, just isn't worth it TO ME, but you might think differently about that then I do.
Back in the 70s when I first started racing I hot waxed my chains, it was a headache, eventually I moved on to Tri-Flow, and while it was a wet lube it wasn't messy from what I can remember, I continued to use it for many years so it must not have been overly messy. Later I tried a drip on wax lube but my chain life cut in half, so I moved on to other lubes, and tried a lot of them. The only one so far that I liked was Rock n Roll Gold, I'm now trying Silca Super Secret drip lube, if that one does not work well for me I will probably go back to R n R Gold; the Gold formula even held up in the rain pretty good, which I doubt the Silca will, but the Gold also kept my chain clean like the Silca is suppose to do as well. I just started using the Silca, so it might take a year before I know.
But that is the nature of chain lube discussion, at least on this forum.This sure was a mouthful.
You don't have to race to enjoy the benefits of a waxed chain 🙄Are you racing? If not, why are you wanting to hot wax your chain?
So you don't wax your chain and don't know anything about modern waxing but you'll just pull numbers from your behind.Now there is the point that can be made that a hot waxed chain can last longer, but trying to find an average difference between a hot waxed chain and wax drip chain was impossible on the internet, but I doubt the difference is more than 500 miles.
So you have zero experience but you think you read something but can't give any facts 🙄I did read the more you hot wax it, like at the 150 mile mark the longer the chain will last, but no numbers were given.
More nonsense. You can just dry it.Also if you get caught in the rain, as soon as you get home you have clean it and hot wax it again.
Nobody asked you if it is worth it to you. He asked for himself.The expense of all of that clean and waxing, plus time, and in my book time is money, just isn't worth it TO ME, but you might think differently about that then I do.
This isn't the 70s. Yea putting candle wax on your chain back then was stupid. But you did it for many years 🙄Back in the 70s when I first started racing I hot waxed my chains, it was a headache, eventually I moved on to Tri-Flow, and while it was a wet lube it wasn't messy from what I can remember, I continued to use it for many years so it must not have been overly messy.
behave, I wasn't lecturing anyone, but you are that's for sure, so go take a bath you stink.You don't have to race to enjoy the benefits of a waxed chain 🙄
I can tell you it's more than 500 miles.
I'm on track for 12,000-16,000 miles on a 12 speed chain. I never got 11,500mi from oil lubes. I bet you don't either
That's nonsense
Guess what... if you don't dry your oil lubed chain after getting caught in the rain it can rust.
Feel free to start your own thread about the virtues of your chain lube. I'm sure the OP won't come by to lecture you
This is 2025. It's an entirely different ballgame.
Of course you were.behave, I wasn't lecturing anyone
