While you are off the bike, drop the chain off the front rings and spin the cranks. Sight downward, standing directly above the rings. Do the ring move laterally side to side, like an out-of-true wheel? Some slight movement is not uncommon, and to be expected. If they spin straight then you may be seeing flex in the frame. Re-aligning (re-bending) can be done, but it can be tricky.
