I just bought a Park Tool chain cleaner and I'm wondering what would be a good and cheap degreaser to use in it. Is any citrus degreaser from the hardware store ok to use ?
That would probably be fine. Other options are rubbing alcohol or odorless mineral spirits. My experience with chain cleaner devices isI just bought a Park Tool chain cleaner and I'm wondering what would be a good and cheap degreaser to use in it. Is any citrus degreaser from the hardware store ok to use ?
I would add that this doesn't need to be done frequently as it completely strips the chain of any lube. It's a very thorough cleaning.Chain cleaners suck. Get a removable chain link, a pickle jar and screw on top, and soak/shake the chain in mineral spirits (which you can let settle and then environmentally-friendly reuse). I usually use two jars, one for an initial cleaning and one for a final cleaning. Then I lube the chain, wipe, and hang to dry. The chain should function like new, assuming you've checked stretch.
Agree with others: if you can return the chain cleaner for a refund, do it.I just bought a Park Tool chain cleaner and I'm wondering what would be a good and cheap degreaser to use in it. Is any citrus degreaser from the hardware store ok to use ?
but most of the timea pickle jar and screw on top, and soak/shake the chain in mineral spirits (which you can let settle and then environmentally-friendly reuse) Then lube the chain, wipe, and hang to dry. The chain should function like new, assuming you've checked stretch.
"Leave chain cleaner alone"In between thorough cleanings, it's sufficient to just wipe down the chain every few rides with OMS and a rag and regular lubing.
Zep citrus degreaser is cheap enough.I just bought a Park Tool chain cleaner and I'm wondering what would be a good and cheap degreaser to use in it. Is any citrus degreaser from the hardware store ok to use ?
they do make a mess.That would probably be fine. Other options are rubbing alcohol or odorless mineral spirits. My experience with chain cleaner devices is
1. They make a huge mess
2. They always break
I prefer to just wipe it down with a rag
What part of your chain has plastic housing?Simple Green is good. I use Krud Kutter that I get from Home Depot. If the chain is not too dirty plain water will also work. Use something that has no petroleum distillates because they will melt the plastic housing .
WD-40 is not a lubricant. It helps, but isn't nearly as good as a chain specific lubricant, and only marginaly cheaper.Then lube with WD40 and wipe down. All good.
occasionally
Actually, WD-40 can be used as the degreaser. Allow to dry overnight, then lube with an appropriate lube.WD-40 is not a lubricant. It helps, but isn't nearly as good as a chain specific lubricant, and only marginaly cheaper.
clean a chain with water...?If the chain is not too dirty plain water will also work.
WD-40 is a lubricant, though a "light duty" lubricant, with its petroleum base oil in its formualtion. Yes, it was designed as a water displacer, so it displaces water and replaces that water with a thin oil film.WD-40 is not a lubricant. It helps, but isn't nearly as good as a chain specific lubricant, and only marginaly cheaper.
Yes, it has a high amount of solvents in its formulation.Actually, WD-40 can be used as the degreaser. Allow to dry overnight, then lube with an appropriate lube.
