Why do you want new wheels? What's wrong with your old ones?
//See above
What are you old ones? (rim name, hub name, spokes, their numbers)
//Specialized Axis Elite, axis hub, 24 spoke
How much do you want to spend?
//love to stay under $500
How heavy are you?
//160 Pounds
Do you ride "light" or "heavy"?
//light
Are you powerful or smooth?
//prob more smooth then powerful
Have you had problems with your current wheels and if so, what?
//not till i broke em other then thinking of possible tubeless upgrade
What condition are the roads in that you ride?
//fair some potholes
What tires, widths and pressures are you using?
//current tires are 26 75-80psi, have considered 28-32
What do you expect from your new wheels that your old ones can't deliver? (be reasonable and realistic here!)
//lighter would be nice able use use up to 32mm tires would be great.
What are you going to use the wheels for - recreational riding, touring
(loaded), training, racing, general purpose?
//All of the above... i do short triathlons, have started to get into touring, but more then anything truly will be recreational
Do you want custom hand-built (designed for you) or factory pre-built?
//dont care
Do you want wheels that are easily repairable with readily available, reasonably priced spokes and rims or are you ok with maybe having to ship your wheels back to the factory and wheels that contain expensive, proprietary spokes and possibly un-obtainium replacement rims?
//would prefer easily repairable
Do you need 11spd compatible wheels (can be used with 8 ~10spd cassettes too by using a spacer) or are 10spd wheels ok? (can only be used with 8 ~ 10spd cassettes). Edit - This info is for Shimano & SRAM related cassettes; not Campagnolo.
//11 spd
Do you want the wheels to be oriented towards "aero" or "light"?
// not sure it will matter that much for me i can go either way
Do you want to use regular clincher, tubeless, or tubular tires?
//clincher for sure maybe tubeless in the future
Aluminum or carbon rims?
//alum.. wish i could afford carbon but i cant
Rim brakes or disk brakes?
//disc
Rear hub width? (120, 126, 130, 135MM)
//not sure.. i have a 2017 specialized Roubaix elite
Do you want adjustable loose ball bearing hubs (almost exclusively Shimano) or cartridge bearing hubs (almost everything else)?
//doesnt matter
