I searched around a bit and found some information, but would like some more. Has anybody added dimples to chainstays to add a little bit of tire clearance? This would be on a steel frame. I sort of impulse purchased a frame, and it doesn't quite live up to the specs. It's supposed to clear a 32, and while a 31.9mm wide tire fits and spins with about 1mm of clearance on either side, it's not really ideal. One ride resulted in rubbing paint. There's about 34mm of clearance between the stays at the widest point on the tire.
This is before the tire swelled a bit:
I have a 30 on it now, and it's slightly better, but I didn't buy this to run a 30.
How realistic is it to add dimples to an already built and painted frame? Will it damage anything? Has anybody done this as a DIY? I know it'll void the warranty, but that's OK. I did come across a builder that added chainring clearance to a completed frame with shaped wood and a clamp, and that turned out well.
Or is this one of those "sell it and buy the right frame" sort of deals?
