Might be a stupid question but I've always heard that when you rebuild a hub you should only hand tighten the axle...correct?
If you're suggesting you could do the final tightening of the locknuts against the cones without wrenches, that's NOT correct. There's no way you could get them tight enough not to slip. Obviously you do the initial rough adjustment of the cones by hand, to avoid overtightening and damaging the races. But then the cone wrenches come into play. And as Dave said, it's a bit of an art getting it all secure with the perfect adjustment.gnauss said:Might be a stupid question but I've always heard that when you rebuild a hub you should only hand tighten the axle...correct?
