Large and Small
teleguy57 said:
Dave, I'm looking at the chart right now and the installation instruction pdf, and I'm seeing Campy 10-spd shifters with jtek#1 entering large side. For Campy rear it's showing 10 spd Shimano cassette, and for SRAM rear it's showing SRAM or Shimano 10 speed cassette. Am I missing something that you're seeing?
No, T'Guy, but this gets at the Shiftmate choice palette.
Again, for the model #1 Shiftmate:
* For Campy 10-speed shifters
and Campy rear derailleur
and Shimano 10-speed cassette, it's as you say, with large pulley on the inside
* However, I was referring to Campy 10-speed shifters
but with Shimano
9-speed cassette, which requires the small pulley on the inside
See, the only parts variable that changes is the number of cassette gears, even same brand. That parts change alone changes how the pulley needs to be installed.
(The SRAM rear derailleur with either SRAM or Shimano 10-speed cassette, also small pulley.)
Hope that helps.
Dave,
who says the inner pulley is always the pulley the cable enters first but that inner could be large or it could be small but it's never medium
