quattrotom said:
I like the Zinn articles, but when things get complicated mechanically, his intuition and explanations are typically a little off (see his articles on rotational weight and that whacky company he advised? with spring loaded spokes).
Here is where I think he is missing something... His explanation would be great if the opposite of fork flex and cable "stretch" was true. If the fork flexed under hard breaking and resulted in a slacking of the cable, then you would have a nice harmonic type response leading to something like shudder shown in his picture. But this is not the case and he correctly says this in the text.
If one were to believe his theory, a fork that didn't flex at all should also have shudder but less pronounced because of his idea of brake pads losing and regaining grip - and nothing should limit this to cantilever brakes. This is like anti-lock brakes as someone else pointed out.
One logical approach would then be to analyze whether a fork flexing and pads 'breaking free from the rim' would lead to a much more pronounced shudder - the kind that makes a bike somewhat uncontrollable. This might be the case, but then his "solution" of putting the cable stop on the fork crown doesn't really matter because the 'extra' cable pull of the 'bad' setup under fork flex could be achieved by just pulling harder on the brake levers ultimately leading to the same pad 'breaking free from the rim' on a flexed fork.
Taking this a step further, a road bike with a really lightweight all-carbon fork under heavy braking should also flex and the brakepad will eventually 'break free from the rim' and cause a shudder - but this doesn't seem to be an issue with most lightweight road bikes.
Unfortunately I don't really have an answer - that's in part due to the fact that I've only thought about this for 20 minutes and I don't get paid to tell people how the mechanics of their bike works. But... I did stay at a holiday inn express last night.
Looks like you didn't understand Zinn's explanation. The flex he's talking about is the flex between the brake and the last housing stop. With a typical setup, the cable stop is above the top half of the headset, way high on the steerer. That's a good distance and the more there is flex between those two points, the more the cable can be pulled and/or let loose when braking to cause the shudder. Brakes can flex, the fork at it's crown, the steerer, might be some little play in the headset, alone individually, it might not be much but they can add up.
On a road bike or with a v-brake, the housing stop is part of the brake so you elmiminate the fork flex, steerer, headset... pretty much everything. Even with a flexy fork, it could bend noticably under braking but it wont change how much cable is pulled, the brake is 'isolated' from the influence of the flex further than the brake mounts. Plus a road caliper is usually much stiffer than a canti. Using a fork mounted stop eliminates a big chunk of the portion that can flex as most fork flex at the crown and steerer junction, not much between the brake mounts and the crown.
