Let me first say that good wheel building does not rely on the use of a tension meter. Wheel builders have been relying on the tensioned spoke tone consistency for ages and excellent wheels have been built by plucking the spokes and listening to the tone they make.
Personally, I prefer using the meter to arrive to equal spoke tensions (relative tension) around the wheel and also know when my tension goal has been reached (absolute tension).
I do find the TM-1 capable of adequate repeatability, essential to determining the relative tension between spokes. My meter shows a deviation of no more than 5kgf which is further reduced to within 3kgf by the uniformity of the squeezing action (hard squeeze vs. soft squeeze + tap). Overall, pretty decent on that end.
Where I find the meter to be off is the absolute tension measurement and the point of the thread is to best avoid using it for such purposes unless the meter is calibrated for the particular spoke in use. Calibrating the meter is really a very simple process involving hanging the spoke, apply a known weight, use the meter to read the spoke tension and compare the listed mass (force)with the actual mass. Its best to calibrate the meter for each spoke type and even for each spoke batch. Doing so I found my meter reading tensions 19kgf higher than the actual value when calibrated against 14/15/14 ga. Sapim spokes (graduation #23 actually corresponds to 111kg rather than the charted 130kg). This is a substantial difference that could result in insufficient tension if not properly accounted for.
