1 - 8 of 8 Posts
mackgoo
Discussion starter · #1 ·
My C Record rear free hub axle is bent. I'm looking for a replacement on eBay. Are the rear axles pretty much universal. If my rear spacing is 126 mm what should I get as far as a length 128, 130?
Sutherland's 4th edition(1985) has these dimensions for a Campagnolo axle
Thread--10mmx26TPI
Over locknuts--125mm
Axle length--134mm
Dimension A--35mm (this is the measurement from the shoulder that the freewheel buts up against to the outside face of the axle locknut)
Chainline--43.5 (from center of the hub to middle of the mounted freewheel, which would be the center cog on a 6spd freewheel.)(Do Not put the freewheel on a hub that isn't built into a wheel, Big Mistake. You probably know this, but I thought that it's worth mentioning.)
I dug out my Campy catalog 18 (Super Record, Record and lower groups pre 1985) and 18 bis (C Recd, Victory, Triomphe groups) . The part number for the C Record and Record rear axle is the same , 29/R. Listed as 132 mm in catalog 18 whereas no axle lengths listed for any hubs in 18 bis.
Nuovo Tipo hub in cat 18 is listed as part 29 , 127 mm long. Axles for Triomphe and Victory Hubs are part # 420/004.
Discussion starter · #8 ·
Thanks for the research. I'll either get the one in Boulder, but I'm checking one other source as I don't need any of the other hardware.
1 - 8 of 8 Posts
