Shimano Ultegra Hydraulic Brakes Compatible With Shimano MTB Lines???
2 reading
2.8K views 4 replies 3 participants last post by  kafin8ed
#1 ·
I'm disassembling one bike with Ultegra Di2/hydraulic and building another, going from post mount Shimano calipers to flat mount Ultegra calipers, keeping the levers. Ive bled a bunch of MTB stuff, not road but I have the tools. My real question is I need a longer rear hydraulic line and have a long Shimano line from an MTB with a banjo bold on it. It looks like I can just cut off the banjo bolt and insert the brass fitting and it will work, is that a safe assumption to make?
#2 ·
Sounds reasonable. Make sure you use the right fittings, Shimano has 2 types...1 has the silver barb, the other is brass. Both use brass olives. There are also 2 types of brake hose, you can check the Shimano site to confirm what you have and which fittings to use.
#3 ·
Good to know, I did a little more research, I actually have ST-R785 levers which are Alfine not Ultegra, my derailleur is Ultegra. The user manual on the Shimano site doesn't say anything about what type of hydraulic line or olive/insert to use, where do you get that info? I have BH90 olives/inserts, which I think are what the Ultegra R8000 use. I just need to double check the housing I have because it's new old stock MTB with SM-BH63 stamped on it. I'm going to re-use the the rear line on the front brake so I know it will fit, I just need to figure out this MTB one and if it's compatible.
#4 ·
Do you know what the part numbers for the current and new calipers are? As far as the hoses go, Shimano currently uses SM-BH59 and SM-BH90. The BH63 is an older hose. I don't know its exact differences, so I can't really compare it to the two current hoses. The BH59 and BH90 have slightly different internal diameters, so it is important to use the proper one for the lever/caliper that you're using. si.shimano.com lets you look up a ton of good tech info and also takes you to the spec/compatibility site at productinfo.shimano.com
So long story short, I wouldn't recommend using that older BH63 hose for this project. The ST-R785 levers use the BH90 hose, so as long as your new calipers require that as well, then grab yourself a new pack of BH90.
#5 ·
They are the Ultegra BR-R8070 F and matching rear calipers. OK I already assembled and bled everything - it seems to be working just fine but I haven't ridden it yet. If I can track down a newer hose then I can swap it in pretty easy. Thanks for pointing me to the si.shimano.com site - that would have come in handy!
