Should square tape bottom bracket tapers be greased/oiled? I thought I read they should not have any grease/oil. But I saw one bike store greased my spindle. Is the grease to prevent seizing?
What do the crank/BB instructions say?steel515 said:Should square tape bottom bracket tapers be greased/oiled? I thought I read they should not have any grease/oil. But I saw one bike store greased my spindle. Is the grease to prevent seizing?
If you're worried about galvanic corrosion but don't want to use grease because of the possibility of slipping, you might want to consider some medium (Blue) Loc-tite or similar thread-lock compound.steel515 said:Should square tape bottom bracket tapers be greased/oiled? I thought I read they should not have any grease/oil. But I saw one bike store greased my spindle. Is the grease to prevent seizing?
If you've worked at all with square taper spindles with appreciable mileage, then you have had to seen evidence of fretting. Many square taper faces have small residual "ridges" left over from the machining or grinding processing to make the flat face. After removing a crank after many miles of use, I'm sure you've noticed that some of these ridges have become worn down or smoothed off where they contacted the crank. This "wear" is due to fretting (micro-motions) between the crank and spindle.curlybike said:also never had any evidence of galling, fretting or corrosion.
What more can you want?
Mark McM' reply is dead on. The important thing to note is that the crank will work its way up the spindle after it has been ridden hard. It is then subsequent torquing of the crank bolts that often leads to cracking of the crank at the spindle bore, because once the bolt has been tightened the crank will squirm its way up the spindle a little more. The best thing to do is install the cranks with a light coating of grease, use some blue loctite on the bolts, and torque them to spec. Then leave them alone until they have to removed.terry b said:You'd think someone would have shared that information with Campagnolo, because page 18 of their crankset installation instruction pamphlet says, "Before you install the cranks on the bottom bracket axle, degrease the axle and the crankset square heads thoroughly."
And somehow they've failed to update their instructions in these intervening 20+ years. Or bothered to do any follow-up testing.Eric_H said:I suspect Campagnolo's instructions are a result of the well-known failures of the older Campy Super Record cranks from the early-mid 80s.
So you are then under the assumption that every single component in the Campy line has been engineered and tested to its maximum? Somehow I doubt it. The bike industry is filled with "engineers" who pass along gospel as fact and I'm sure there are a couple who exist at Campy. Jobst has his flaws, but he is a smart guy who rides his bike a lot and is also a guy who really makes an effort to understand the workings of bicycles from a fundamental level. I am not bashing Campy, I have a basement full of Campy with no Shimano left to be found. Here are some more examples of their instructions:terry b said:And somehow they've failed to update their instructions in these intervening 20+ years. Or bothered to do any follow-up testing.
Yet the compelling evidence of "experimentation" appears to suggest that it's a bad idea to install without grease and such an installation can lead to damage and failure. Funny that Campy just can't seem to get it together.
I find it really amusing when a bunch of hobbyists think they're smarter than people who design, build and sell this stuff for a living. I see it all the time in my work, not suprising that we as cyclists fall into the same trap.
In reality though, I think this topic is a classic case of cognitive dissonance. Ever since the first time our daddies put a wrench in our hands, we've been told you always grease a metal to metal interface. Along come these instructions that contradict that well-held value. We say "bah" and then go off and build a case for why we're right. Even to the extent of believing it because it's on the internet and because Jobst Brandt said so. Human psychology is an amazing thing. Yet in my case, in 20 years of building and riding I've had one crankarm come loose - the square taper that I greased. I'm sure that was because I failed to properly torque it.
