I searched but no dice. I found information on elevation but not on grade accuracy.
Are Strava's grade percentages accurate?
I would say some are and I would say some are not.I searched but no dice. I found information on elevation but not on grade accuracy.
Surprised you didn't find anything because this has been discussed at great length and repeatedly. Try searching just on Strava and then ignore the stuff that doesn't deal with grade and altitude.I searched but no dice. I found information on elevation but not on grade accuracy.
Strava (or any other similar software/hardware tool) has no access to any instruments that would measure grade directly. Grade is not measured, it is calculated. It is calculated as a ratio between the total elevation gain and planar projection of the total distance traveled. This gives you average grade for any given segment.Are Strava's grade percentages accurate?
