A few months ago I got some new Pacenti SL23 rims and carefully applied 2 layers of Stan's tape before mounting some tubeless tires. Tire mounting issues aside, I inflated the tire and seated the beads easily the first time using just a floor pump. This weekend I was due for some new tires so I got some replacements and put them on. Not only would the beads not seat with a floorpump, a very manly high CFM air compressor couldn't get the job done either. No amount of soapy water or fiddling around with the tire made any difference.
Eventually I figured out why I couldn't get them inflated. After several months of exposure to 80-100 PSI pressures the Stan's tape had deformed/stretched enough so that relatively deep dimples formed in the spoke holes. Due to the Pacenti's very tight tire fit and the off-center drilling pattern, the tire beads inevitably end up sitting right in the middle of these dimpled spoke holes in the center channel. When you try to inflate the tire and seat the beads, all the air just rushes out these dimples- it's the proverbial rabbit hole under the fence times 28 and 32. Finally I caved in and just bought and re-applied the Stan's yellow tape and sure enough, the beads seated easily with a floor pump.
Sooo... any thoughts about how to avoid this issue? I don't want to have to spend an additional $5 per wheel on Stan's tape every time I have to remount a tire, not to mention the extra time hassle to remove and re-apply the tape. I know other people use alternatives to Stan's, but if they eventually stretch as well the end result will be the same. Veloplugs aren't an option due to the Pacenti's already very tight fit. FYI I stretch the Stan's tape out as much as humanly possible when applying it to the rim.
Note: I'm not trying to flame Pacenti here, as except for tire mounting issues, I am extremely happy with the rims. I can imagine this is a common problem with other tubeless ready rims as well.
