1x lacing - all elbows pointing out?
16K views 23 replies 10 participants last post by  ericm979
#1 ·
A guy I was riding with the other week had a 1x laced front wheel. Instead of alternating elbows in/out all of them were pointed out.
It looks like this:
Are there any disadvantage or issues of doing it this way?
Also, in a front wheel does it matter which spoke crosses on the outside of the other? From looking at that pic on the side we are looking at the "left" spoke crosses over the right one, but if we flip the wheel around the "right" spoke would cross over the left one.
Discussion starter · #4 ·
1x and radial heads in is something that we used to do but we've gotten away from it seeing as it puts unnecessary stress on the hub flanges. It doesn't matter whether the left goes over right right, or vice versa. As long as it is consistent throughout the system.
Are you saying that 1x in general puts extra stress on the flanges or both elbows out does?
So the wheel pictures is not consistent correct?
Discussion starter · #11 ·
Actually there's lower stress on the elbows with heads out.
How so? By making the spoke touch the hub flange it'll put some force on the flange instead of on the elbow itself from my understanding.
I don't quite understand why my lacing will cause the wheel to assplode. I'll ride it all year and let you know.
I have no idea either, I'd be interested in hearing what Zen says.
Discussion starter · #15 ·
Wow, so many lacing choices for front wheels! I am building a 24 spoke front wheel using A/C 2218 rims and BHS wide flange hubs. I am considering radial, 1X, and 2X. Now, if I use 1X I have to decide to alternate spoke heads or build all elbows out. It doesn't sound like it is a big deal stregth-wise as the wheel should be fine w/ any of those patterns. I guess my main question is if 1X whether to go all elbows out or not? Any issues w/ flange or hub body strength of the BHS hubs for radial lacing? Thanks a ton for all the great advice guys.
I'm 172lbs. and mostly ride mountains of colorado.
Even more choices will all elbows in :p
