3rd set of BB90 bearings on 2012 madone 6.2
It sounds like my problem isn't unique after reading these posts. I have a 2012 Madone 6.2 and the non-drive side bearing has failed twice in under 1,500 miles, and I think the 3rd bearing is on the way out. I bought the frame new on Ebay and had the frame built out with Ultegra components. The first time the the non-drive side bearing went bad, the shop replaced it and said that it went bad from water intrusion. I never wash my bike with a hose and it never gets wet because I do not ride it in the rain. The bearing were dry and made a squeaky wheel type of noise. The mechanic noticed that the grease was a rust color and that is why he concluded that the bearing somehow got wet and failed. The first set last about 1400 miles. The second set failed in four rides for a total of about 200 miles. Same high pitched squeaking noise and only the non-drive side. I even went so far after the bearings were replaced to put a small bead of silicon just above the bottom bracket area so any water coming from my water bottle in the cage would be directed around the bottom bracket shell opening; that seems to really work in keeping water from entering this area.
I noticed that there was no axle shield installed when the bike was built out, but I just assumed that it wasn't needed because the mechanic that did the build out gave me the extra parts that he didn't use. I bought the frame new on Ebay and it came with some extra stuff. The mechanic that built my bike no longer works at that shop, so when the 1st bearing failed to took it to another reputable shop near where I live. The mechanic there was the one that mentioned possible water intrusion and proceeded to replace both bearings. But he didn't install the axle shield either which I discovered today when I removed the crankset to take a look. I called a Trek dealer (there are none within a 100 miles of where I live) and the mechanic said that the axle shield should be installed.
Everything that I have read about this bike says that the bearings can be removed and installed by hand since they just go right into the frame and that a press isn't necessary. Well, I cannot remove the bearings by hand because they seem to be pretty tight in the shell. I want to remove the bearing so I may install the axle shield because I am thinking that this may help. The Trek mechanic said that the axle shields are part of the bearing kit because they should be used for this bike.
One last thing that I want to mention that could be part of the problem: the part of the axle that comes into contact with the inside of the non-drive bearing has a slight ring on the surface from where it comes into contact with the bearing, but the ring on the axle is not continuous; it goes maybe 2/3 of the way around the axle. This tells me that the bearing may not be aligned in the frame correctly, and I am wondering if the axle shield would make a difference. I am not even sure exactly what the purpose of the axel shield is since since the axle is concealed in the frame. Do the flanges at the ends of each half of the seal play any role in the bearings being aligned?
Fortunately, I do not have the problem of loose bearings in the frame like some others have experienced. Since I bought this frame on Ebay, I know that Trek will not warranty it, so I want to be careful to not mess this fame up. Any ideas on how I should remove the bearings and reinstall them? Thanks!
