Just bought a Cervelo R3 which comes stock with a Rotor 3DF crankset. Really like the bike and the Rotor 3DF crankset, but the crank arms are too long for me. Seems like the BBright standard that Cervelo employs on their bikes will somewhat limit my replacement options, but I think I’ve found some viable solutions. Since I’m completely unfamiliar with BBright, I think it would be helpful to get some guidance from the wrenches here in hopes of doing the fix correctly the first time. Thoughts? Any other good options or issues I’m overlooking?
Option 1:
Rotor 3D+ crankset
Pros: this is the easiest swap out since the bottom bracket will not need to be replaced. This is a definitive upgrade compared to the stock cranks and other options under consideration
Cons: expensive for a crankset - will set me back about $600
Option 2:
Rotor 3D24 Crankset + Rotor BB4624L
Pros: Less expensive, the crankset and BB swap will cost around $450
Cons: slight weight penalty (no big deal). If I'm shelling out this kind of money, should I just go ahead and get the 3D+ for $150 more? not taking advantage of the BBright technology?
Option 3:
Shimano Ultegra FC-6800 crankset with Wheels MFG BB (ABEC-3 BB FOR 24MM (SHIMANO) CRANKS)
Pros: Least expensive option at around $400, familiar with Ultegra cranks and overall Shimano performance/dependability
Cons: Looks like the Wheels MFG BB option is fairly new, so it doesn’t seem like there’s a lot of use cases/reviews to evaluate. Will this combination negate the supposed benefits of the specifically designed Rotor BB and cranks for the BBright standard?
Notes:
- Rotor 3D30 crankset is not an option since they don’t come in the crank arm length I need
- Wheels MFG BBright adapters with Enduro bearings don’t seem like a good option compared to using a bottom bracket made specifically for the BBright standard.
- Considered doing the work myself, but I have no experience or tools for press fit BBs. Rather than investing in new tools and possibly messing up a nice bike while learning, I’ll have an LBS take care of this. Already doing a lot of other work on the bike — I just wanna ride the darn thing!
Option 1:
Rotor 3D+ crankset
Option 2:
Option 3:
Notes:
