I have a 1988 Raleigh Technium frame that I purchased as a first project bike. I am trying to learn how to tear down and rebuild bikes. This bike threw a curveball already when I tried to fit some standard Shimano Cantis on it. The bosses are reversed, meaning the three little holes are toward the outside of the frame instead of inside. It is this way for all four brakes.
Because of this when you try to put the brakes on there is too much tension when trying to use the hole attachments.
I think I found a solution by using older Dia Compe 987 Cantis where the tensioner is contained in a "spring box" and the holes are irrelevant. What do you think?
