So, I have a 2012 Cervelo R3 and the "dropout derailleur hangar" part of the frame broke off with the derailleur! Which totally sucks on my side because when I finally have time to ride my bike... this ish happens.
I did have an accident a month ago but things seemed ok but when I put it on the trainer... it cracked off when I mounted the bike.
So, its one of two things...
#1 - I just moved it to the side too much and it cracked or...
#2 - the accident jacked it up more than i saw and it was the main cause instead of blaming the trainer.
Here is my question? What should I do?
A. I spoke to a guy who can fix the carbon portion for about $600.
B. Try to get a Cervelo warranty but the LBS is saying that the Cervelo "crash replacement" only gives you 25% off of a new frame. I totally thought that if my frame had a major accident/issue... they would replace it for shipping and handling only? Or is the LBS wrong? 25% off of new frame would be $1500.
C. Get a new frame and just re-use the parts?
Im a big dude 6'1" 280 and my only goal is to ride long distance. Maybe hit some group rides and such but Im only out there to ride. And of course... lose weight! But, is it worth buying a steel frame or a "more durable" frame like a cyclocross frame to handle my weight? Purchase a parley or a Sarto or something like that? Just looking for opinions... right now... I think im going to pull the trigger on the frame fix. But, im hoping that im not wasting a $1000 (frame fix plus remove parts plus refit) instead of spending that $1000 on a new frame...
