I'm trying to remove an FSA Gossamer crankset from a Cervelo S5 (BBRight PF30 Bottom Bracket Shell).
I've worked w/ FSA PF30 cranksets before and it's usually as simple as unscrewing (normal threading) the crank bolt on the NDS crankarm until it falls off.
However, when I unscrew (normal threading, I'm turning my 10mm Allen Key counterclockwise) the bolt, it feels like it loosens temporarily then it feels like it tightens a lot.
I've had this happen before, where it feels like it tightens, but I just push through it and it eventually works out. Bad threading or something. However, it's never been this tight.
Is the crank bolt reverse threaded? Am I doing something wrong? Should I just push through it? It's really, really tight after I "unscrew" the crank bolt.
