lloking for wheels for 8 speed campy.
11K views 13 replies 11 participants last post by  dookie
#1 ·
Hi, I am looking to replace my wheels for my 8 speeds campy.
Can I just buy a cheap pair of Kamshin/mavic aksium...wheel set and put my 8 speeds on it?
would a spacer do it? I see cheap set going for under $200.
I have been looking and most wheel set offer 9-11 speed compatibility..but nothing about 8 speeds. Would my 8 speed fit on a 9 speed campy? any tricks?
I know 8 speeds is old..but this is for my winter bike and all work well so I don't want to upgrade to 10 spd.
Any advise.
thanks.
#2 ·
Cassette body is different. An 8 speed cassette body will not fit on most new campy hubs. You may have to look on Ebay for 8 speed hubs or wheels.
#4 ·
In case your shop doesn't know what to order, you need the "red" spacer kit.
#7 ·
I am pretty sure Campy 8 speed splines do not fit on Campy 9/10 freehubs
Here's the best way to do this:
1. New Campagnolo 9/10/11 compatible rear wheel
2. 9 speed cassette with individual cogs and spacers (probably Veloce)
3. 8 speed spacer kit from Wheels Mfg. or Campagnolo
Remove all 9 speed spacers and one of the 9 speed cogs (usually the 26 or 28)
Replace the 9 speed spacers with the 8 speed spacers and install 8 of the 9 cogs
#10 ·
Campy 8 speed freehub bodies do not accept 9/10 cassettes and vice-versa.
I have the setup you referenced so I can run a lightweight set of newer wheels on my 8 speed Record bike (I also have a 10s Campy ride.) It works beautifully. I don't even have to do minor tweaks to the rear derailleur - it lines up perfectly.
If the OP is eventually going to convert his 8s bike to 10s, then that would be the way to go.
The downside is the expense. I can get 2+ 8s Sram cassettes (which also work with the Wheels Mfg. spacer kit) for the price of one Veloce 9s. The Campy 9s to 8s spacer kit is more expensive than the Wheels Mfg. one. And Shimano compatible rear hubs/wheels are all over the place at all price points. Campy, not so much.:(
#14 ·
yes, some misinformation here...
8s and 9/10s use the same spline pattern, but the 8s splines are much shallower. 9/10 cogs will not fit on an 8s hub, because the splines are too deep for the grooves in the body. the reverse is *not* true however...
8s cogs *will* go on a 9/10s hub, but i strongly suggest you do not ride this combination. because the cog splines are much shallower than the body grooves, and the 9/10 body is now alloy (vs steel for the 8s body), there is not sufficient area of contact to distribute the load, and the short steel 8s splines will quickly gouge the freehub body.
