Hi all,
I am planning to build a new wheelset but I first need to choose which rim I will get. I need input on how the new XR31T compare with the other Kinlin rims.
I currently ride a wheelset made up of Mavic Open Pro on Shimano 105 5800 hubs laced with Sapim Laser spokes. Tire is a Continental Gatorskin 25mm. I want a lighter more aero wheelset. I tried a friend's Mavic Ksyrium SL with Michelin Service Course Pro 4 (23mm) and I liked it.
After some research, I have settled on BHS or Novatec hubs, Sapim Laser or Cxray spokes and a set of Continental gp4000s tires, probably 23mm. I like the options on Kinlin rims, however, there is very little out there on the new XR31T to help my decision.
I have seen opinions comparing the XR300 vs the XR270 and general consensus seems that the XR270 is more forgiving to side winds. Does this translate to the XC279/XR31T comparison?
I have also seen opinions that the XC279 is better than the XR270 for its ride quality (mainly due to the wider rim) and it may have a better aero profile (more rounded as opposed to a deep V). I believe this still applies to the XR31T compared to the XR300. Is this correct?
Cxray spokes have a slight aero advantage over the laser spokes, however they are much easier to build with because any spoke twist is easy to spot and fix. They do have quite a price premium. I doubt I would be able to feel much difference in how a wheel feels between the two spokes. I believe the choice may depend on budget and whether it is included in a wheel build kit or not.
As for the hubs, I haven't seen much between the two I have selected (BHS (SL79 & SL210) and Novatec (A291SB-SL & F482SB-SL-11 ABG)) and I would probably go with whoever I buy my kit from. Both are quite light compared to a standard set of Shimano 105 hubs.
Should I go ahead with a XR31T kit (Both BHS or BDOP have them) or should I go for a slightly shallower rim (XC279) and make my own "kit" and not have to worry about how the wheel feels with side-winds. I don't want to be tossed around into the traffic lane when a semi passes by but do want to enjoy the aero benefits of a slightly deeper rim.
In a nutshell: How's the Kinlin XR-31T?
For Reference:
XR-270 19mmW 27mmD 445g
XR-300 19mmw 30mmD 465g
XC-279 23mmW 28mmD 490g
XR-31T 24mmW 31mmD 486g
Mavic Open Pro 19.5mmW 18.5mmD 435g
For Reference:
