Proponents of T47 are quick to point out that owners of problematic metal frames equipped with PF30 shells can be immediately retrofitted. By design, T47 threads can be cut directly into a PF30 shell with no additional changes – although actually doing so is easier said than done. And as any veteran shop mechanic will attest, there’s also no guarantee of success even if you do everything right.
One of t47's biggest obstacles may be that good solutions for creaky press-fit frames already exist. by threading the cups to each other, even persistently noisy frames can quiet down nicely: one of t47's biggest obstacles may be that good solutions for creaky press-fit frames already exist. by threading the cups to each other, even persistently noisy frames can quiet down nicely
“I do not see taking a current PF30 bike and then machining new threads being a smashing success,” says bike mechanic guru Calvin Jones of Park Tool. “It will take some very expensive tapping systems, not simply new taps used on old handles. Threads in an English bottom bracket shell sold as a tube are cut by a lathe. So for nice threads, you should be using two taps with this conversion: one to make a rough cut and a second follow-up for the final cut to full pitch diameter. One tap that is staged in two diameters might do the job, but piloting these into a smooth shell straight will be tricky.
“The circumference of the English cups is about 110mm, but these will be about 145mm, meaning a lot more surface contact and hence the force required is higher,” Jones continues. “Tapping is not a simple process. There will be some cases where everything is done by the book and the threads are trash. Your initial PF30 shells (like all shells) vary in hardness, bore sizing, amount of warp, plus issues in materials.”
