Pulsating when braking on front wheel
4.8K views 14 replies 9 participants last post by  ericm979
#1 ·
On one of my wheelsets, the front wheel pulsates when braking. It doesn't matter which bike I run the wheels on, it still does it. The wheel itself appears to be very true visually when spinning it on the bike.
What causes the pulsation? Is it the way that I have the pads set up on the braking surface?
I'm at a loss.
Thanks in advance.
Brandon
#2 ·
Could be a number of things. What is your wheelset? My first suspicion is usually the seam, how is your rim joined? Has it always been this way or did it start after some time of ownership? Have you checked the rim surface for anomalies or buildup? Bulge in sidewall?
#3 ·
My hoops are Kinlin XR19's with Sapim Laser spokes. Originally I had these wheels on my 31 year old steel frame, but I had thought it was a loose or bad headset. Recently switched them to my Focus, and it still does it, which means that they've always done it. They are about a year old at this point. I have looked at the rim and haven't noticed any kind of build up on them at all. Sidewalls look good on both sets of tires that have been mounted.
#7 ·
As others have explained it is most likely the rim joint. Try taking a sanding block to the rim sidewall at the joint (on both sides) to smooth out the bump. Another possibility is that the rim took a hit and bulged the sidewall someplace else.
#13 ·
Thanks all! I didn't have time to take the tire off as of yet, but did flip the wheel around this morning before a quick ride and it did make it better. Still a slight pulse, but better. I'll work on getting the tire off and inspecting the rim a bit more closely this weekend.
#15 ·
Rim widths often vary around the wheel. If the variation is more than about .1mm, it causes the brakes to pulse noticeably.
It's easy to measure with a set of digital calipers. The tire must be removed. A quick way to check for width variation is to set the calipers at the valve hole then rotate the rim with the calipers in place. You'll see if the rim varies. Then to measure the variation, take measurements at every spoke or every other spoke.
Some rims have non parallel brake tracks. Those are not as easy to measure.
