I just started playing with Synchro and Semi-Synchro shift on my DI2 setup. I don't see any compelling reason that the two modes must be mutually exclusive. Is there some way to have both functions active together?
Ok, thanks for the direct answer. That's unfortunate.Short answer: no; it's either one or the other.
I see them as very different concepts. One moderates the jump in gear ratio when you manually shift the FD, and the other lets you avoid cross chaining and makes it possible to use the right shifter to access your entire gear ratio range without using the left shifter. It should be feasible to integrate the two. However, given that Shimano has dictated it otherwise and I don't have the resources to hack the logic to do something else, it is what it is.Longer answer: full synchro mostly includes all of what semi-synchro does. That is, when the system, while in full synchro, decides to shift up front it will offset at the rear the same way that semi-synchro does. In addition, while in full synchro you are free to shift the FD manually on your own, whenever you wish. The one thing "missing" from full synchro is that when you shift the FD on your own while in full, there is no offset at the back.
Semi-synchro is NOT that smart. It's not doing any sort of calculations. The "semi-synchro" mode is really just one function: whenever the rider manually shifts the FD, the system automatically moves the RD the other direction (as an offset) by 1–3 cogs. The amount the RD moves is chosen in the settings.I'm actually not that clear on how useful semi mode is in function I understand that when you manually shift the FD the system figures out where you were in terms of gear inches, (or whatever) and moves the RD to the next "harder" gear. I think.
That's essentially what I'm doing on mine. You should have no trouble.The system in theory allows a maximum cog move of 6 cogs, but only 4 in semi mode. I'm not sure if that means you can configure a move from a 34/12 to a 50/17, as I would be when using a 34/50 and 11-23. That would be a great automatic move. Likewise I'd love to use a 50/21 to a 34/15 which is the next logical move if doing it manually.
Time will tell if the system allows it.
I see what you're saying. I just spent an hour trying to duplicate your intended map and couldn't make it work. My best guess is that's a bug in the software.No matter what I try there is one hard and fast rule: I cannot set a FD downshift that occurs in anything other than the largest or second-to-largest cog.
The conundrum of cheating the Di2 system.
1) Shimano has discontinued producing my favorite cassette, the 11-23 (they could not explain why), thus you have to cheat Di2 by telling it you are using a 12-25. Sucks as I like this cassette for flat Long Island riding as it has one tooth jumps from 11 to 19. It's still usable in Di2 (and available to buy), but see below.
2) If telling Di2 you have a 34/50 crank, the system will not allow access to the 2nd smallest cog, what Shimano calls the 10th cog. They state this is to prevent cross chaining, yet it's allowed on other cranks. They won't change this limitation. I asked.
3) The results of the above are that you also need to lie about the crank, a 36/52 will allow access to the 10th cog.
4) When viewing the cog/crank gear locations on a Garmin or whatever, the readout is incorrect as to the Gear Combo. When you are in a 34/12 it's actually saying 36/13. Makes the whole point of getting this readout on your computer somewhat useless. This is a nit-pick somewhat, until you recall what the system costs.
5) Shimano is truly being Big Brother with this and is yet again choosing what works for the masses and not allowing much in the way of customization.
