21 - 33 of 33 Posts
I was just about to rip out my bb to hunt down a similar sounding noise. I already have the teflon tape so was surprised to have an issue.
I notice whilst manoevouring the bike that a creak noise seemed to be coming from the headset lower bearing area.
On closer inspection I actually isolated it to where the cables enter the barrel adjusters on the down tube. IE The 'spring-loaded' ajjustment. A drop of oil there knocked it on the head.
Will find out 7am tomorrow if I still have another noise.
Discussion starter · #23 ·
Thanks guys...the pedals are Look Keo and have less than 700 miles on them and I only ride in clean conditions. I would be shocked of both pedal bearings needed service so early on, maybe one if something was wrong, but not both. Good idea with the cables...I will add it to the list. It also sounds like mine is coming from front end, but I got 'as light as I could on the bars' and cranked and it was still there. I HOPE I don't isolate everything else and have to have headset pulled. I put front wheel against a wall last night and pushed up down and 'torqued' bars and could not get any clicking. With it happening twice a revolution, it makes me think it is crank/BB, cassette, or hear hub. I will put a drop of chain lube on locations where barrel adjusters go down the downtube.
Any resolution with the noise? I have the same issue; creaking noise from headset when pedaling. This even happens when not touching the bars. I haven't tried to break down the headset yet as I would like to find the most likely culprit. In what area of the headset would get the most stress from pedaling? Creaking noise lessens when I stand (no it is not the seat).
Discussion starter · #25 ·
I have greatly reduced it. It was either one of the pedals or headset spacers or front wheel quick release. Not sure which as I cleaned greased all of them between a ride with clicking and one with almost zero clicking.
Almost zero clicking = the clicking did not come from the greased parts, but rather something adjacent you touched during the greasing activity. Did you take off the pedals and put back on? Did you lube the threads of the pedals?
Did the wheels change their position after putting them back on?
Noise is a funny thing, I had a noise once that was driving me crazy, only under load, up hills. It turned out that when I was sliding back on my seat for power my thighs were rubbing on the velcro saddle bag strap around the carbon post. Boy did I feel dumb:blush2: after taking it back and forth to the bike shop thinking something was wrong with my bottom bracket.
On other occasion I was getting bad noise under load only. It turned out that my Sram casset was loose, once tight no more noice, and I could go up 1-gear higher on the big ring.
I had the similar issue with my Cervelo R3 SL (Sram Red, ZIP 303) and it was driving me crazy about 6 weeks. The creaking when standing turned out to be coming from the bottom bracket (which I cleaned, regreased and re-torqued to fix) and the constant clicking on each pedal stroke was resolved with one little drop of oil on the rear quick release hinge. I am now back in love with my Cervelo - it was dicey for a while.
I've experienced a click I was able to localize to the large gear of my (triple) chainring. I was able to correct it with some slight derailleur adjustments to the front and back. They were just slightly off and causing the chain to hit one of the rivets on the ring. Another contributing factor was my frame itself, and it's not something I can correct. My Vitus 979 frame has a fair bit of flex at the bonded joints. If you're riding a bicycle with some flex in it, that could be the cause. There's really not much you can do about that except to be extremely careful with your drivetrain adjustments, and keep an eye on the chain and the teeth of the chainring for signs of wear.
DrSmile said:
Did you check the pedal bearings? From what you wrote it seems like you just took off the pedals and re-torqued them onto the cranks.
I know the OP's issue has been resolved. But I just bough a brand new bike and immediately changed the stock pedals with brand new pedals. There was less than 10 miles on the NEW bike and NEW pedals when I developed a click mashing down on the left pedal. I disasembled the pedal and applied some good waterproof grease. No more click.
The fact that the click occurs at the same point in the pedal stroke for both feet makes me wonder if your shoe is where the click is happening. Or, for that matter, if your rear shoe may be flicking the front derailer cable. Good luck. You've got quite the mystery going.
Check your cable housings where they meet the stops on the front of the frame. They make some pretty horrible clicking noises when the inner wires poke out and rub against the ferrule.
Grab the housings and twist them around. You'll know it if you hear it.
21 - 33 of 33 Posts
