I now have a kickr2. I have had at least 3 kickrs. Considering getting a neo. However, I would like some input on whether the Neo is actually better than the kickr for my particular issues with the kickr.
Over all of the kickrs I have owned, none of them actually hold a constant power in erg mode.
Here are a couple examples from trainerroad workouts. These are both in erg mode, power matching to my quarq elsa and a pretty constant 85-95 cadence for the about 80 minute and 90 minute rides. Small chain ring, center of cassette, no shifting.
The power data lines (yellow) are from a quarq PM.
As you can see power over the long intervals is not constant (normal is about +/- 15 watts or a 30 watt spread; the larger jumps are around +/- 25 watts or a 50 watt spread). The two workouts below have long interval lengths.
The top one is 10 minutes per step. The bottom one is 8-12 minutes on the longer blocks.
If I turn off power matching, I get the same type of power fluctuations from the kickr. So, it is not caused by the two (crank PM and the kickr) trying to match to each other.
Same thing happens whether or not I do a spin down.
The fluctuations get frustrating. If I come off a long interval barely alive, I want the power to drop right now. If I want to ride at 250 watts for an hour, I don't want bouncing up and down between 230 watts to 280 watts for an hour.
I have also noticed that the flywheel gets HOT. After 45 minutes or so, the flywheel is very hot to the touch. I don't have a temp on it. But, I wouldn't want to drink coffee that is that hot.
If I just rely on the kickr power alone, I get perfectly straight lines. Those perfectly straight lines are not what is really happening. IOW, the kickr thinks it is giving level power, but it is not.
If you have a Neo and a crank based power meter, do you get similar results or does the Neo actually hold more constant power?
Thanks
Thanks
