Tektro R580 Brakes ... May be a stupid question ...
14K views 5 replies 6 participants last post by  frdfandc
#1 ·
I'm familiar with mountain bikes. I am well familiar with my Avid BB7 Disc Brakes. They are simple. All I have to do is release the skewer on either the front or rear wheel, and they drop out.
Now, these road bikes are an entirely new beast.
Is there a simple way to disengage the Tektro R580 brakes to take the wheel off, perhaps in need of changing a flat? There is a little lever that you can flip, but it doesn't nearly disengage the brakes enough to slide the wheel off past the pads.
What am I doing wrong?
#2 · (Edited)
The quick release tab is located at the spot where the brake cable is pinched at the caliper.
Twist the quick release up, and it will open up the caliper a few millimeters and let you slide the wheel in/out.
Edit: If you twist the quick release up and still don't have enough clearance to pull the wheel through, consider adjusting the calipers out with the barrel adjuster by a couple of millimeters, so when you twist the quick release upwards, you'll have more space.
#3 ·
Twist the quick release up, and it will open up the calipers a few millimeters and let you slide the wheel in/out.
Yeah, 'cept he said he did that, and it didn't clear.
You may have your brakes set up with the pads too close to the rim. They might work better a little more open.
Otherwise, you have to deflate the tire a little.
#6 ·
My 25c Gatorskins were a little tight when I had the 580's on my road bike. I just let a little air out and they fell out.
The Rival calipers I'm using now, have a little more clearance.
What you can do is loosen up the pinch bolt, screw out the barrel adjuster a few turns, re-attach the cable to the pinch bolt. When you have to take off the wheel, flip the lever and give the barrel adjuster a turn to give you more clearance.
