Lusting for new bike and want a lugged steel, looking at Tommasini. What others should I consider?
Cinelli and Colnago still make lugged frames but if I was buy new, I'd look at this. New frame but retro paint.BNA_roadie said:Lusting for new bike and want a lugged steel, looking at Tommasini. What others should I consider?
Dave Hickey said:Cinelli and Colnago still make lugged frames but if I was buy new, I'd look at this. New frame but retro paint.
http://www.excelsports.com/new.asp?...ge=8&description=Super+Record+78+Frame+and+Fork&vendorCode=GIOS&major=1&minor=1
euro-trash said:Most companies no longer offer steel frames in their normal stock, however, if you call them, they will be more than happy to build you one. They miss working with lugs. Going this route, however, won't be cheap (but the frame will last so long, the question is, does it matter).
I've not seen a 16.5 OEM lugged frame, but I bet the ride would be great, and the weight wouldn't be bad. Let us know what you get.
Don't forget to check out eBay.BNA_roadie said:Lusting for new bike and want a lugged steel, looking at Tommasini. What others should I consider?
Italian steel crafted in the US. Go with Della Santa.BNA_roadie said:Lusting for new bike and want a lugged steel, looking at Tommasini. What others should I consider?
Nessism said:EOM16.5, UltraFoco, S3, and similar, are intended to be TIG welded.
Ed
why did you do this? i was having frugal thoughts, elevated, w/ no desire for anymore material belongings and you had to post this..Dave Hickey said:Cinelli and Colnago still make lugged frames but if I was buy new, I'd look at this. New frame but retro paint.
Yeah, I want one of those, too. Funny thing is I don't even want to ride it. I just want to own it.colker1 said:why did you do this? i was having frugal thoughts, elevated, w/ no desire for anymore material belongings and you had to post this..
Ricky2 said:Actually, due to the heat treatment and super thin walls of those tubes, True Temper and Colombus says that the preferred method is lugless fillet brazing. TIG is the 2nd choice, but distortion is much more a factor due to higher localized heat. The tube ends are as thin as .5mm! Lugs are not an option because of the non-round shape of each of the tubes.
I have one of these that I bought in 1982 and built up with Campy Super Record. It is a sweet ride, but the Columbus SL tubing and the titanium bottom bracket flexed just a tad (I was around 200 lbs then). Took the ti BB and put in my wife's Pinarello and the flex went away. Bile doesn't have more than a 1,000 miles on it (drifted away from cycling for a number of years and now back but love that STI), but it is so beautiful I can't part with it.
The lugs are very classy - not overdone as some are.
Howard L. Snell
Nessism said:Where did you learn about the recommendation to fillet braze these materials? I'm not sure this is true for Columbus anyway. Columbus's '04 catalogue give specific reference to recommended TIG and MIG welding filler rods, but no mention of fillet brazing at all.
http://www.ceeway.com/Columbus-Tubing.htm
In terms of total heat added to the tubes during joining, TIG is much lower than fillet brazing. TIG is higher temperature process, but the total amount of time needed to make the joint is much much lower, thus the lower total amount of heat.
Fillet brazing adds another risk; undercutting the tube during the fillet finishing process. TIG does not have this problem, thus TIG is better for super thin tubes.
Ed
Howard2 said:i just picked up an 82 gios SR with a mix of SR and NR. should be here tuesday. can't wait.Dave Hickey said:Cinelli and Colnago still make lugged frames but if I was buy new, I'd look at this. New frame but retro paint.
Howard L. Snell
Columbus provides information on which welding materials to use because they know many builders will be welding the tubes together. No specific reference is made to what brazing materials to use. If brazing was the "recommended" method to join the tubes, you would think they would make some reference to filler materials wouldn't you?Ricky2 said:Lon at Nova Cycles (US distrib fo Colombus) told me this once. Colombus 04 catalog is wrong if they are recommending MIG welding for ANY such thin steels. MIG welding is TERRIBLE choice from a frame and can you name 1 single builder in the world who MIG welds his frames? Doubt that.
Check Carrera at www.redroseimports.com Shield model I think.Nessism said:Bottom line is that you're not likely to see any lugged frames using any of these super-steel tubesets anytime soon.
Ed
Nessism said:Columbus provides information on which welding materials to use because they know many builders will be welding the tubes together. No specific reference is made to what brazing materials to use. If brazing was the "recommended" method to join the tubes, you would think they would make some reference to filler materials wouldn't you?
As far as MIG is concern, it's not common to MIG a main triangle but some builders do MIG for dropout attachment.
Regarding the "best" joining method for these super-steel tube sets, it's one mans opinion against an others. While most tube manufacturers do not make specific requirements, it's well understood that both TIG and fillet brazing is viable. Of the two, fillet brazing requires a lot of care since undercutting is a real risk on super thin tubes. Saying that fillet brazing is "recommended" is a real stretch, I doubt Lon would get agreement to his claim from any of the major tube manufacturers.
Ed
Man, thanks for all the links, just made my job just a bit harder.unchained said:Don't forget to check out eBay.
I have a Tommasini already. If I were to buy another frame, and cost were no object, it would be the Hampsten Giro '88, partially because I admire Andy himself, and the Richard Sachs lugs.
Gios Compact Pro from importer/dealer excelsports.com. Get them to order in a threaded steel fork for you, for whatever reason they only carry threadless. Frame appears to be a great value. Short top tube and steep seat angles.
Viner, Casati, Colnago Master, Merckx MX Leader - gvhbikes.com. Good prices.
Casati - These have a great reputation, get the EL/OS if they have your size. http://www.racycles.com/sd/catalog/sd_rf_casati_249036_products.htm
Marinoni - http://www.marinoni.qc.ca/, Italian born, now living in Quebec. They do their paint and chroming in house. They may not show lugged in their catalog, but they will still build it to order.
Mondonico/Torelli - see your local bike shop. Expensive.
Carrera, Ciocc, DeBernardi, Guerciotti, Moser, Pinarello, closeouts - http://www.highcaliper.com/
Cinelli Super Corsa - nice chrome and paint. A classic with standard size tubing. http://stores.ebay.com/trek-2a-Bicy...Store-4-Tires-nMore_Road-Frame_W0QQcolZ2QQdirZ1QQsclZallQQsotimedisplayZ2QQtZkm
DeRosa closeouts - www.ridecampy.com
Masi - from his son in Italy, importer seems to be a bit of a "card" - http://www.creative-web-sites.com/milano_sport/homepage.htm
US builders, there are one or two of them, some you probably have never heard of that produce stunning frames (like Chris Kvale?) www.classicrendezvous.com/USA/USA.htm
and that is just the start...
I bought a custom made frame from a small builder out in Los Angeles named John Waite, and he MIG'ed many a frame together. He builds mostly track frames so appearance is not a big issue for him. On the frame he made for me, he TIG'ed the main triangle but MIG'ed the dropouts - I watched him. I understand that one man is not an island, but you seem to insist that no one uses MIG and this is wrong.Ricky2 said:Fair enough. You still haven't told me 1 single builder who uses MIG for dropout construction. So, if you know of one and it can be verified by website, phone, whatever then I will eat my words. I don't believe it.
Richard
Nessism said:As far as preferred joining operations, I just dug out an old Columbus product catalogue and they state regarding the then new Genius tubing "Developed exclusively for TIG welding".
Ed
Ricky2 said:Genius tubes, notwithstanding, are what now? Over 10 years old? And the differential butts are .7mm at the ends. Quite a difference compared to the newer steels of today with butts of around .5mm. In any case, you were right COlumbus did market that tubeset as great for TIG. This won't happen again. If it did, then they would have stated as such. As to the guy in CA who MIG welds dropouts. OK. You did find one guy. I suppose that the dropout being thicker than regular tubing, maybe you could justify MIG instead of TIG or fillet-brazing there. Very uncommon though, since your example is the 1st that I've heard of a builder doing MIG welding.
Dave Levy at Ti Cycles, who does both TIG welding and fillet-brazing, and who also builds all of the Hampsten Steel S3 frames had an option to do the construction with TIG, which would be alot faster and more economical. Or to fillet-braze which is the most time consuming to do. The choice is clear. Fillet-brazing. This speaks volumes. Here's a builder who does both and he chose fillet-brazing, even if it wasn't more economical. The ends are .5mm. You will never see any filing undercutting on any Ti Cycles frames or Hampten frames or the frames go in the dumpster before they get to a customer.
