I just started playing with Synchro and Semi-Synchro shift on my DI2 setup. I don't see any compelling reason that the two modes must be mutually exclusive. Is there some way to have both functions active together?
Nah, the 11-40 isn't supported by the software at all. In fact neither is the HG800 11-34, which is meant to be to used on road/gravel bikes.
I just checked the setup on the 11-28 and it works the same. You should be able to do it. Apparently the key is what Steve B pointed out that the start and end points have to be within a gear ratio delta of 1.0 (or at least *think* they have a delta of 1.0
What? So my last gen Ultegra won't include the HG800 because ... it's a last gen derailleur and this is a current-gen cassette? Wow, that's like having a old pump that doesn't work on 29ers. It doesn't even make any sense, a firmware update should bring it in line.The cassette choice is based on the RD part number. If you're not seeing the newer gen cogsets, I'll guess you aren't using the new-for-2017 Di2 parts. Same way the crankset gear choice locks out based on road vs MTB HTII parts based on what FD-line you use.
Naturally.And aside from Garmin's "Gears" readout...what Di2 think the gearing is matters not at all IRL.
I see what you're saying. I just spent an hour trying to duplicate your intended map and couldn't make it work. My best guess is that's a bug in the software.No matter what I try there is one hard and fast rule: I cannot set a FD downshift that occurs in anything other than the largest or second-to-largest cog.
Thanks for taking the time! It wasn't for nothing, since now I'm slightly more confident that I'm not going crazy!!I see what you're saying. I just spent an hour trying to duplicate your intended map and couldn't make it work. My best guess is that's a bug in the software.
E-tube really is like iTunes some days. The HG800 exceeds the tooth-count spec for 6870 (GS is 32T max)...so it probably will never show up. I plugged an 8050RD into my rig and 11-34 appeared right away.What? So my last gen Ultegra won't include the HG800 because ... it's a last gen derailleur and this is a current-gen cassette? Wow, that's like having a old pump that doesn't work on 29ers. It doesn't even make any sense, a firmware update should bring it in line.
Whatever, sounds like Shimano thinks they're Apple or something.
Naturally.
Well, Shimano has always taken a Big Brother approach in terms of deciding what's best for the consumer, witness the whole line of cassettes starting at 11. Who actually needs that ?.E-tube really is like iTunes some days. The HG800 exceeds the tooth-count spec for 6870 (GS is 32T max)...so it probably will never show up. I plugged an 8050RD into my rig and 11-34 appeared right away.
I have yet to make sense of Shimano's arbitrary lockdowns of certain things based on cog tooth count. 6870 had it too. IIRC 52/36 only had 2 multishifts allowed whereas 53/39 and 50/34 had 3.
As to the first issue: there is nothing to 'set' in manual mode, so the app doesn't deal with that. The app configures settings for semi and full-synchro, and then when on the bike you use the junction box to toggle between the 3 modes. So this one isn't an oversight on Shimano's part.OK, in middle of an 8050 upgrade install and very frustrated.
1) The iPhone app seemed useless, then I downloaded the PC app and connected via the battery BCR2
Here's the issues:
- No ability to set to manual shift mode, synchro or semi seem to be it
- No 11-23 cassette option, in any crank type.
- No indication of battery charge on app's
- How to set to Gear Position Control adjustment ability for Do Not Set ?, this would let me manually use the 12 cog in manual mode, which I can not configure.
I mean is Shimano kidding ?, this is Nanny State BS
Unhappy with this
1) Read the junction box manual.OK, in middle of an 8050 upgrade install and very frustrated.
Here's the issues:
Unhappy with this
Yes, you guys are correct that you can set to manual in the A Junction.1) Read the junction box manual.
2) The cassette option is honestly just fluff functionally, beyond the Garmin Gears field.
3) I don't think the app has ever had a battery status indicator
4) GPC is based on your crankset choice....for whatever reason.
Had a revelation last night that it matters not, in some respects, as to what cogset and crank the system is told you are using.E-tube really is like iTunes some days. The HG800 exceeds the tooth-count spec for 6870 (GS is 32T max)...so it probably will never show up. I plugged an 8050RD into my rig and 11-34 appeared right away.
The conundrum of cheating the Di2 system.
1) Shimano has discontinued producing my favorite cassette, the 11-23 (they could not explain why), thus you have to cheat Di2 by telling it you are using a 12-25. Sucks as I like this cassette for flat Long Island riding as it has one tooth jumps from 11 to 19. It's still usable in Di2 (and available to buy), but see below.
2) If telling Di2 you have a 34/50 crank, the system will not allow access to the 2nd smallest cog, what Shimano calls the 10th cog. They state this is to prevent cross chaining, yet it's allowed on other cranks. They won't change this limitation. I asked.
3) The results of the above are that you also need to lie about the crank, a 36/52 will allow access to the 10th cog.
4) When viewing the cog/crank gear locations on a Garmin or whatever, the readout is incorrect as to the Gear Combo. When you are in a 34/12 it's actually saying 36/13. Makes the whole point of getting this readout on your computer somewhat useless. This is a nit-pick somewhat, until you recall what the system costs.
5) Shimano is truly being Big Brother with this and is yet again choosing what works for the masses and not allowing much in the way of customization.
Yes, I discovered that last night that the whenever the Garmin does it's BT connection with Di2, it grabs the configuration out of Di2, over-writing what you changed on Garmin.What is annoying about the Garmin readout...you can customise your gears in your Garmin itself and have them read correctly....BUT...it resets after every ride.
Also note that only the cog tooth count and ratio fields are effected....that cog position readouts still work fine.
