Please post your bike model, height, stem length, and frame size:
Model Dogma 2 BoB
Rider Height: 6'1"
Frame size: 57.5
Stem: FSA 120mm
Model Dogma 2 BoB
Rider Height: 6'1"
Frame size: 57.5
Stem: FSA 120mm
I'm always surprised when someone talks of changing the offset of the seatpost to adjust the ETT.Zero-offset post might help me run a longer stem on the 57.5 for steering and load, but stills feels like tinkering to make up for frame that's too big.
Yes, this is true. The only things a zero offset seat post would achieve are the correct position for the rider if when using the setback seat post the saddle could not more any further forward and the aesthetics if it's on the limit.I'm always surprised when someone talks of changing the offset of the seatpost to adjust the ETT.
Isn't it true that you have to adjust the saddle to the right position first, and then play with the stem?
The saddle is set according to your leg and femur length, knee angle, KOPS (if you want to use it) etc. There is only one perfect spot for your saddle and moving your butt forward or back from that ideal spot can create other positioning problems.
Hi Phildhom,Hello,
Want to buy Dogma 65.1 think 2. My length is 176 cm and current saddle height is 70 cm. I'm hesitating between a 50 cm and 46.5 cm frame. Can somebody give some advice
Hi Phildhom,Hello,
I want to buy the same bike. I'm 1m75 and i have a saddle height of 70 cm. i seen that you have a 54 with a 90 mm stem. I had for myself a 50 in mind.Is a 54 not to big?
I what size stem are you using?2015 Dogma 65.1
Rider Height: 5' 7"
Frame Size: 47
Fits and rides like a dream!
